Finding the distance modulus and the absolute magnitude
The discussion focuses on calculating the distance modulus and absolute magnitude of a star with an apparent magnitude of -0.4 and a parallax of 0.3 arcseconds. The relevant equations include the distance modulus formula, m - M = 5 log d - 5, and the absolute magnitude formula, M = m + 5 + 5 log(pi''). The parallax angle in arcseconds is directly related to the distance in parsecs, with 1" corresponding to a distance of 1 parsec. The user successfully applies these equations but seeks clarification on the correct usage of the parallax measurement.
  • Understanding of apparent and absolute magnitudes in astronomy
  • Familiarity with parallax measurements in arcseconds
  • Knowledge of logarithmic functions and their application in distance calculations
  • Basic concepts of stellar distances and their relation to astronomical units
  • Study the relationship between parallax and distance in parsecs
  • Learn about the significance of distance modulus in astrophysics
  • Explore the calculation of absolute magnitude using different apparent magnitudes
  • Investigate the implications of parallax measurements in observational astronomy
Astronomy students, astrophysics enthusiasts, and anyone interested in understanding stellar distance calculations and the concepts of magnitude in astronomy.
Benzoate
If a star has an apparent magnitude of -.4 and a parallax of .3'' what is :
a) the distance modulus
b) the absolute magnitude
m is the apparent magnitude and M is the absolute magnitude
m-M =5 log d - 5
M= m + 5+5 log(pi''), pi'' is the parallex angle
In order to find the Absolute magnitude, M, I apply the equation M= m + 5 + 5log(pi'')
I can easily find M since m and pi'' are already given in the problem. The only trouble I'm having is I don't know what units of measurement I'm supposed to convert pi'' to or if I'm suppose to leave pi'' the way it is.
the parallax angle, in arcsec, is the reciprocal distance in parsec.
So, (recall abs.Mag.definition) 10 pc means .1" , which has
M = m + 5 + 5*log(.1) , = m like it should.
The parallax angle, \pi, is customarily given in arcseconds, but it is the (narrow) triangle involved that makes it clear how to use it. A parallax angle of 1" is the angle subtended by the mean radius of the Earth's orbit (more accurately, the semi-major axis), which is 1 AU, at a distance of 1 parsec. This automatically defines the parsec in terms of astronomical units (it also explains the name of the unit...).
What you'd want to think about it how that angle changes for other distances. You then have a simple relation between the stellar distance, d, in parsecs, and the parallax angle in arcseconds. The angle \pi is often used interchangeably with the distance. The distance d in parsecs is what goes into your distance modulus equation (the modulus (M-m) is also used by some astronomers interchangeably with distance).
Noting many of the threads you've started lately, you wouldn't happen to be in an introductory astrophysics course, would you?
