Finding the eigenfunctions and eigenvalues associated with an operator
41 replies · 5K views
JD_PM said:
Consider the following operator
$$\hat Q = \frac{d^2}{d \phi^2}$$
Find its eigenfunctions and eigenvalues.
The eigenvalue equation is
$$\frac{d^2}{d \phi^2} f(\phi) = q f(\phi)$$
Well, since Orodruin didn't answer my questions I will post the last message, sorry if I'm being repetitive:
1) ##f_1## CAN BE a normalizable periodic function.
2) ##f_2## IS NOT a solution to the problem stated at the beginning.
Good luck.
JD_PM said:
We have
$$f_2(\phi) = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
Let's apply the given boundary condition ##f(\phi +2\pi ) = f(\phi)## to ##f_2(\phi)##
$$D e^{i (\phi + 2\pi) \sqrt{q}} + E e^{- i (\phi + 2\pi) \sqrt{q}} = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
$$D e^{-i \phi \sqrt{q}} + E e^{i \phi \sqrt{q}} = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
$$D(e^{-i \phi \sqrt{q}} - e^{i \phi \sqrt{q}}) + E(e^{i \phi \sqrt{q}} - e^{- i \phi \sqrt{q}}) = 0$$
Mmm but this implies that ##D=0## and ##E=0##, which leads to the trivial solution.
There must be something wrong in here... I am thinking.
I'm still not sure how we got here! To go back to the beginning. For the equation:
$$\frac{d^2 f}{d\phi^2} = q\phi$$
We can write down the solutions:
$$f_1 = e^{\sqrt{q}\phi}, \ \ f_2 = e^{-\sqrt{q}\phi}$$
Now, we know that an exponential of a real variable is not periodic. And, we know that the exponential of an imaginary variable is periodic, via Euler's equation:
$$e^{i\phi} = \cos \phi + i\sin \phi$$
We need, therefore, ##\sqrt q## to be imaginary. I.e. we need ##q## to be a negative real number.
Moreover, the required periodicity of ##2\pi## implies that ##\sqrt q = in##, for ##n = 0, 1, 2 \dots##.
We claim, therefore, that the eigenvalues of ##\frac{d^2}{d\phi^2}## (when restricted to ##2\pi##-periodic functions) are ##q_n = -n^2##, each with two eigenfunctions:
$$f_{n+}(\phi) = e^{in\phi} = \cos(n\phi) + i\sin(n\phi), \ \ f_{n-} = e^{-in\phi} = \cos(n\phi) - i\sin(n\phi) $$
Except the special case ##n = 0##, where there is only one eigenfunction ##f_0(\phi) = 1##.
And that's all that there was supposed to be to it.
Finally, note that linear combinations of these eigenfunctions are also eigenfunctions. For example:
$$g_{n_1} = \frac 1 2 (f_{n+} + f_{n-}) = \cos(n\phi), \ \ g_{n_2} = \frac 1 {2i} (f_{n+} - f_{n-}) = \sin(n\phi)$$
Gives an alternative pair of eigenfunctions with eigenvalue ##-n^2##.
There is, therefore, no unique solution in terms of eigenfunctions. The solution is actually a 2D eigenspace (for ##n \ne 0##).
I have to say that, to me, what you are saying here is correct.
However I want to also follow what Orodruin is saying, to see where we end up.If we are all correct, we should get the exact same answer right? :)
Yes, of course. It depends how long you want to spend on this.
Orodruin said:
What is the real part of ##e^{i\sqrt q \phi}##?
$$\cos(\phi \sqrt q )$$
Ahhh
So using Euler’s formula we end up with
$$(2D - 2E)\sin(\phi \sqrt q ) = 0$$
Let’s label a new constant; ##F=2D - 2E##
Thus we have
$$F\sin(\phi \sqrt q ) = 0$$
Let's assume ##F \neq 0##. Thus
$$\sin(\phi \sqrt q ) = 0$$
$$\phi \sqrt q = 2\pi n$$
$$q = \frac{4\pi^2}{\phi^2} n^2$$
Where ##\phi \neq 0##. OK to match the correct eigenvalue solution (##q_n = -n^2## as PeroK showed; note that Griffiths states the same solution as PeroK) we need ##\frac{4\pi^2}{\phi^2} =-1##. This looks awkward to me, there has to be something wrong in what I have done...
I am afraid I really like trying different methods in the problems I solve... I cannot avoid to at least try and see what I get 😆
I don't understand this step at all.
$$D e^{i (\phi + 2\pi) \sqrt{q}} = D e^{-i \phi \sqrt{q}}$$
Right?
Mmm so I am stuck in here then
Let's see if Orodruin wants to go further.
I am willing to go for the extra method (I am quite curious) but as it is not strictly necessary (I find PeroK's answer satisfactory enough) I would perfectly understand if Orodruin feels it is not necessary.
