- 22,832
- 14,876
What is the real part of ##e^{i\sqrt q \phi}##?
JD_PM said:Consider the following operator
$$\hat Q = \frac{d^2}{d \phi^2}$$
Find its eigenfunctions and eigenvalues.
The eigenvalue equation is
$$\frac{d^2}{d \phi^2} f(\phi) = q f(\phi)$$
JD_PM said:We have
$$f_2(\phi) = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
Let's apply the given boundary condition ##f(\phi +2\pi ) = f(\phi)## to ##f_2(\phi)##
$$D e^{i (\phi + 2\pi) \sqrt{q}} + E e^{- i (\phi + 2\pi) \sqrt{q}} = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
$$D e^{-i \phi \sqrt{q}} + E e^{i \phi \sqrt{q}} = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
$$D(e^{-i \phi \sqrt{q}} - e^{i \phi \sqrt{q}}) + E(e^{i \phi \sqrt{q}} - e^{- i \phi \sqrt{q}}) = 0$$
Mmm but this implies that ##D=0## and ##E=0##, which leads to the trivial solution.
There must be something wrong in here... I am thinking.
PeroK said:I'm still not sure how we got here! To go back to the beginning. For the equation:
$$\frac{d^2 f}{d\phi^2} = q\phi$$
We can write down the solutions:
$$f_1 = e^{\sqrt{q}\phi}, \ \ f_2 = e^{-\sqrt{q}\phi}$$
Now, we know that an exponential of a real variable is not periodic. And, we know that the exponential of an imaginary variable is periodic, via Euler's equation:
$$e^{i\phi} = \cos \phi + i\sin \phi$$
We need, therefore, ##\sqrt q## to be imaginary. I.e. we need ##q## to be a negative real number.
Moreover, the required periodicity of ##2\pi## implies that ##\sqrt q = in##, for ##n = 0, 1, 2 \dots##.
We claim, therefore, that the eigenvalues of ##\frac{d^2}{d\phi^2}## (when restricted to ##2\pi##-periodic functions) are ##q_n = -n^2##, each with two eigenfunctions:
$$f_{n+}(\phi) = e^{in\phi} = \cos(n\phi) + i\sin(n\phi), \ \ f_{n-} = e^{-in\phi} = \cos(n\phi) - i\sin(n\phi) $$
Except the special case ##n = 0##, where there is only one eigenfunction ##f_0(\phi) = 1##.
And that's all that there was supposed to be to it.
Finally, note that linear combinations of these eigenfunctions are also eigenfunctions. For example:
$$g_{n_1} = \frac 1 2 (f_{n+} + f_{n-}) = \cos(n\phi), \ \ g_{n_2} = \frac 1 {2i} (f_{n+} - f_{n-}) = \sin(n\phi)$$
Gives an alternative pair of eigenfunctions with eigenvalue ##-n^2##.
There is, therefore, no unique solution in terms of eigenfunctions. The solution is actually a 2D eigenspace (for ##n \ne 0##).
JD_PM said:I have to say that, to me, what you are saying here is correct.
However I want to also follow what Orodruin is saying, to see where we end up.If we are all correct, we should get the exact same answer right? :)
Orodruin said:What is the real part of ##e^{i\sqrt q \phi}##?
PeroK said:Yes, of course. It depends how long you want to spend on this.
JD_PM said:$$D e^{i (\phi + 2\pi) \sqrt{q}} + E e^{- i (\phi + 2\pi) \sqrt{q}} = D e^{i \phi \sqrt{q}} + E e^{- i \phi \sqrt{q}}$$
JD_PM said:$$D e^{i (\phi + 2\pi) \sqrt{q}} = D e^{-i \phi \sqrt{q}}$$
Right?
