Finding the energy density outside of an isolated charged sphere
The problem involves calculating the energy density in the electric field near the surface of an isolated charged metal sphere, with a focus on the relationship between potential, charge, and energy density in the context of electrostatics.
  • Participants discuss the use of equations related to capacitance, electric field, and energy density. There are attempts to manipulate these equations to express energy density in terms of given variables. Questions arise about the appropriateness of certain substitutions and the implications of the term "near" the surface of the sphere.
Some participants have provided feedback on the original poster's attempts, suggesting modifications and questioning the validity of certain approaches. There is an ongoing exploration of the correct expressions and whether limits should be considered in the context of the problem.
Participants are navigating constraints related to the definitions of variables and the specific conditions of the problem, such as the distance from the center of the sphere to points outside the sphere and the interpretation of the energy density in relation to the sphere's surface.
Coulombus
A charged isolated metal sphere of diameter d has a potential V relative to V = 0 at infinity. Calculate the energy density in the electric field near the surface of the sphere. State your answer in terms of the given variables, using ε0 if necessary.
Since the chapter's homework is focused on is predominantly focused around capacitance, I believe that the equation for capacitance given by ##C = 4\pi \epsilon_0 R##, where R is the radius of the isolated sphere, will be useful. The core of this problem revolves around the equation for energy density given by $$u = \frac 1 2 \kappa \epsilon_0 E^2$$
Along with the Voltage equation ##V = \frac {Kq} R##
and Electric field magnitude ##E = \frac {Kq} R^2##
In both cases, ##K = \frac 1 {4 \pi \epsilon_0 }##
So my first attempt at finding the energy density involved a lot of solving and replacement of variables.
First, I solved the voltage equation for the charge and got ##q = \frac {RV} K##, then I substituted the result into the Electrical force magnitude equation and got this after simplifying: $$E = \frac V R$$
After substituting in that into the equation for the equation for energy density and replacing in R=d/2
My final equation looks something like this $$u = \frac {2V^2 \epsilon_0} {d^2}$$
That solution got rejected, but I think I'm in the ballpark at least. Any suggestions?
Your solution looks OK at the surface of the sphere.
The problem stated "near" the surface of the sphere.
Alright, I've modified my formula to take into account the radius outside the sphere. by replacing placeholder R with ##\frac V {{\frac d 2} + r}## where "r" is the radius approaching infinity. plugging that back into the density equation, I eventually get this $$u = \frac {2 \epsilon_0 V^2} {d^2 + 4dr + 4r^2}$$ but when I tried plugging in that, it was also rejected.
Should I have written it as a limit instead? ##u = \lim_{ r\to\infty} \frac {2 \epsilon_0 V^2} {d^2 + 4dr + 4r^2}##
You solved for Q using D/2 and V.
Why can't you just use E = k Q / r^2 where r is the distance from the
center of the sphere to a point external to the sphere?
  • · Replies 16 ·
