How to Determine the Equation of a Parabola with Given Points and Gradient?
  • Thread starter Thread starter Kafka
    Line
To determine the equation of the parabola defined by y = ax² + bx + c, the constants a, b, and c can be found using the given points and gradient. The curve crosses the y-axis at (0,4), establishing c as 4. The gradient at this point is -5, leading to b being calculated as -5. The curve also crosses the x-axis at (1,0), allowing for the determination of a, which is found to be 1. The final equation of the curve is y = x² - 5x + 4.
Kafka
Hi there,
I have to complete the following question, but I have no idea how to approach it (there are four other parts to the question that I can't complete until I get the first bit). I have made numerous attempts, but am not sure how to get the a part of the equation.
All help would be appreciated!
Thanks,
Kafka
Question
A curve f(x) is defined by the equation : y = ax² + bx + c, where a, b and c are constants.
The curve crosses the y-axis at the point (0,4). At this point the gradient of the graph is -5.
The curve crosses the x-axis at point (1,0).
(i) Find the values of a, b, and c and write down the equation of the curve
Attempt
Sub point (0.4) into equation to get c (x=0,y=4):
y = ax² + bx + c
4 = 0 + 0 + c
c = 4
If gradient at point (0,4) is -5, then dy/dx must be equal to -5.
dy/dx = 2ax + b
-5 = 2ax + b
-5 = 2a(0) + b
-5 = 0 + b
b = -5
*not sure about the bit below*
c=-5, b=4, so sub these into equation of curve and use a point to find a
y = ax² + bx + c
at (1,0) x=1, y=0
y = ax² + bx + c
0 = a1² + (-5 x 1) + 4
0 = a -5 + 4
0 = a - 1
a = 1 ?
Looks good to me :approve:
Now if only PHYSICS students will recognize this as a projectile problem...
Kafka, you did that exactly right.
It does, however, have nothing to do with "differential equations" so I am moving it to the Calculus section.
  • · Replies 20 ·
  • · Replies 19 ·
