Finding the force on an inclined plane
10 replies · 4K views · last reply
cbarker1
MHB
Dear Everybody,
What force (in N) must be applied to a 150.0 kg crate on a frictionless plane inclined at 30° to cause an acceleration of 7.1 m/s2 up the plane?
Work:
I know the sum of the force in the x direction must be equal to mass multiply by acceralation.Thanks
Carter
Let's assume the applied force is parallel to the incline plane...and so we require:
$$F_{\text{net}}-F_g=m\cdot7.1\,\frac{\text{m}}{\text{s}^2}$$
What is the magnitude of the force due to gravity ($F_f$) along the plane?
I believe it is $$m\cdot g\cdot \cos\left({30}\right)$$.
Think about the cases where the plane is either vertical or horizontal...does the cosine function makes sense?
NO, it does not make any sense. so it must be sine function.
Yes, it is the sine function...here's a free-body diagram:
What do you find for $F_{\text{net}}$?
Is that $$F_N=mass\cdot 7.1+m\cdot g\cdot sin 30$$ correct?
Sorry, I have misread the question that there is a force pushing it up the inclined plane.
That's correct, although we know:
$$\sin\left(30^{\circ}\right)=\frac{1}{2}$$
And so we may write:
$$F_{\text{net}}=m\left(7.1+\frac{g}{2}\right)\text{ N}$$
Next, use:
$$m=150.0\text{ kg},\,g=9.8\,\frac{\text{m}}{\text{s}^2}$$
So, what do you get?
Cbarker1 said:
the answer is 1800 N
Yes, I concur. (Yes)
