Finding the height of this triangle
  • Thread starter Thread starter sh86
    Height Triangle
The discussion revolves around finding the height of a triangle using different methods. The initial approach involved using the law of sines, which was successful, but the user attempted a second method involving tangent functions that led to an incorrect quadratic equation. The mistake identified was in the manipulation of the tangent function, where the user incorrectly expressed x in terms of h. A suggested correction was to properly solve for x using the tangent relationship, which could lead to a different result. The conversation highlights the importance of careful algebraic manipulation in solving geometric problems.
sh86
The problem is to find h on this triangle:
http://img215.imageshack.us/img215/7006/triangleum3.png
With the help of the law of sines I've already finished this problem. But I tried doing it a different way and my new solution isn't working and I can't figure out why. Here's what I did:
(1) Break the bottom part like so
http://img221.imageshack.us/img221/3079/bottomba3.png
(2) Use tan to solve for x in two ways
tan40 = h/x (so x = (tan40)/h)
tan47 = h/(125-x) (so x = 125 - hcot47)
(3) Since both those equations equal x, they equal each other, so I do this:
(tan40)/h = 125 - hcot47
Multiplying both sides by h, blah blah blah, I get this
h2cot47 - 125h + tan40 = 0.
So I have a quadratic equation in h. When I use the quadratic formula and do all the solving (which I'll omit since it would take a lot of space to write) I get an incorrect answer. Where did I go wrong?
Your mistake is here: tan40 = h/x (so x = (tan40)/h)
x should be equal to h / tan40
You correctly say
\tan 40 = \frac h x
try solving this for x again. Perhaps you will find a different result. :smile:
LOL! I combed over my solution about a thousand times looking for what I did wrong and I couldn't see that. Thanks guys.
The way I would of done it would of been like so...
I wouldn't of broken up 125 to x and 125-x.. I would of found one of the other sides using sin law because we can figure out the missing angle
\Theta = 180 - (40+47)
\Theta = 93\cdot
then apply sin law
\frac{125}{sin93} = \frac{x}{sin40}
125*sin40 = x*sin93
\frac{125*sin40}{sin93} = x
80.5 = x
then you have the right triangle which is a right angel triangle with the hypotinuse and a given angel.. that's all you need to find h using
sin47 = \frac {h}{80.5}
No, he said he already did it that way, But did it another way and had a problem with that. Nice bit of tex though.
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 21 ·
