Finding the Inductance of a coil
  • Thread starter Thread starter discoverer02
    Coil Inductance
To find the inductance of a coil, the student initially measures the resistance using a 12.0V battery, calculating R as 19 ohms. When connected to a 24.0V(rms), 60.0-Hz generator, the rms current is 0.570 A, leading to confusion about the impedance calculation. The key point is that impedance (Z) includes both resistance and inductive reactance, expressed as Z = R + jωL. By recognizing this, the student recalculates the total impedance and successfully derives the inductance as 99.6 mH. Understanding the role of resistance in the circuit was crucial for solving the problem.
discoverer02
I'm stumped by the following problem.
To determine the inductance of a coil used in a research project, a student first connects the coil to a 12.0V battery and measures a current of 0.630 A. The student the connects the coil to a 24.0-V(rms), 60.0-Hz generator and measures an rms current of 0.570 A. What is the inductance?
When the coil is hooked up to the battery R = V/I = 12V/0.63A = 19 ohms. I'm not seeing how this comes into play in finding the solution to the problem.
Z = impedance.
w = radial frequency
j = imaginary number
L = inductance
V = Voltage
I = Current
w = 2pi(60Hz) = 377 rad/sec
I(rms) = V(rms)/Z
Z = jwL
0.570A = 24.0V/[jL(377rad/sec)] this isn't right because it produce the right answer.
What am I missing? A nudge in the right direction would be greatly appreciated.
The answer in the back of the book is 99.6 mH.
Thanks.
Z = impedance.
L = inductance
V = Voltage
I = Current
I(rms) = V(rms)/Z
Z = jwL
Thanks.
The nudge is that the resistance of the coil is important to the problem. Impedance (Z) is the result of both the inductive reactance and the resistance.
Z =jwL is only true for a circuit with zero resistance.
for a series circuit you would have
Z= R+jwL
And you can treat this coil as an inductance in series with a resistance.
Bingo!
I got it. Magnitude of Ztotal = 42.1 ohms
R = 19 ohms
w = 377 rad/sec
and (magnitude of Ztotal)^2 = R^2 + (jwL)^2
plug in the numbers, do the math and you get .0996 H.
Thank you very much for the help Janus.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
