Finding the inductor value with a frequency range
To find the inductor value for a series RLC tuning circuit resonating at the middle frequency of 55.2 MHz, the formula 1/(2*pi*sqrt(LC)) is applied. The circuit utilizes a 15.8 pF capacitor. Initial attempts involved calculating inductance using the lowest, highest, and middle frequencies. A clarification was made regarding the use of the correct units in calculations. The discussion highlights the importance of unit accuracy in solving for inductance.
cummi3em
A television channel is assigned the frequency range 53.2 to 57.2 MHz. A series RLC tuning circuit in a TV receiver resonates in the middle of this frequency range. The circuit uses a 15.8 pF capacitor. What is the value of the inductor (in mH)?
1/(2*pi*sqrt(LC))
I tried using the above equation to solve for L using the lowest, highest, and middle frequency
What have you got for the middle frequency?
ehild
55.2 MHz
Sorry, :) I meant the inductance at the middle frequency.
ehild
thank you but i got it i was using the wrong units
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
