Finding the intergral function (dy/dt = a(q-y))
  • Thread starter Thread starter miniradman
    Function
43 replies · 7K views
miniradman
I was working on an assignment and when I got my draft back, my teacher said I've made some errors working this out, however I'm not sure what I did wrong...
Find the intergral function of:
dy/dt=a(q-y) where t ≥0, y(0)=0 a and q are constants.
[itex]\frac{dy}{dt}[/itex]=a(q-y)
[itex]\frac{dy}{}[/itex]=a(q-y)dt
[itex]\frac{dy}{(q-y)}[/itex]=adt
[itex]\int\frac{dy}{(q-y)}[/itex]=[itex]\int adt[/itex]
ln(q-y)=at+c
q-y=eat+ec where: ec is a constant so let it = A
q-y=Aeat
-y=Aeat-q
[itex]\frac{-y}{-1}[/itex]= -(Aeat) [itex]\frac{ (-q)}{-1}[/itex]
y= -Aeat+ q
∴ y= -Aeat+ q
Can anyone see any mistakes?
ln(q-y)=at+c
Your mistake was in converting from the first to the next statement. Try and think where the mistake is.
Hint: What is the derivative of ln[f(x)]?
I know the derivative of ln(x) to be
[itex]\frac{1}{x}[/itex]
The derivative of ln[f(x)] is f'(x)/f(x), where f'(x) is the derivative of f(x) with respect to x.
Substitute f(x) = x into this formula to convince yourself that the formula I wrote is a generalisation of the derivative of ln(x).
Then try to work out the derivative of ln(q-y), where q is a constant.
wow... why must I divide the derivative function by the original function?
You mean 'why must I divide the derivative function by the original function to obtain the derivative of ln[f(x)]?
I think you are asking why f'(x)/f(x) has to be the derivative of ln[f(x)]. This is a very theoretical question, and as such it is unlikely to come up in your tests. But just so you know, that formula can be obtained by considering the mother of all formulas you have ever studied in differentiation. It is this:
[itex]\frac{dg}{dx} = \underbrace{lim}_{h \rightarrow 0} \frac{g(x+h) - g(x)}{(x+h) - (x)}[/itex], where [itex]\frac{dg}{dx}[/itex] is the derivative of a function g(x) with respect to x.
This is the fundamental definition of the differentiation of a function and all other formulas that you have learned can be obtained by using this mother of all formulas. For instance, to obtain the derivative of ln[f(x)], substitute g(x) = ln[f(x)] in that fundamental definition and work out the result. The result has to be f'(x)/f(x).
On a more practical note, d/dx { ln[f(x)] } = f'(x)/f(x) means that d/dx { ln(x) } = ?
Try to work out the answer and then find d/dy { ln(q-y)}.
I've always had trouble deriving by first principles, could I use the chain rule?
let ln(q-y)=ln u?
where u = (q-y) where q is constant
then
[itex]\frac{d}{dy}[/itex] = [itex]\frac{d}{du}[/itex] x [itex]\frac{du}{dy}[/itex] ?
let ln(q-y)=ln u?
then
Oh no! Don't try to find d/dy { ln(q-y) } using first principles. I elaborated on first principles just to answer your question on why you must divide the derivative function by the original function to obtain the derivative of ln[f(x)].
Anyway, by the looks of your last post, you appear comfortable with the topic of differentiation, so try the chain rule.
And you can check that you will get the same answer if you use d/dx { ln[f(x)] } = f'(x)/f(x).
so.
d/du = 1/u
du/dy = -1?
d/dy = 1/(q-y) x -1
d/dy = -1/q-y
errr... this can't be right, can it?
ln(q-y)=at+c
q-y=Aeat
-y=Aeat-q
y= -Aeat+ q
∴ y= -Aeat+ q
Do you know how to do integration by substitution?
that would not be ln(q-y). it will be -
Nope, I've only learn the basic rules for intergrating trigonometric and basic polynomials (i.e. f(x)). Also the basic rule for intergrating 1/x which equals lnx
Also the method that I used in my opening post... which I guess hasn't gotten me anywhere =D
Consider
[tex]\int \frac{1}{q-y}dy[/tex]
Let
[tex]u = q-y[/tex]
Then
[tex]\frac{du}{dy} = -1\rightarrow dy = -du[/tex]
We then substitute using q-y = u and dy = -du
[tex]\int \frac{1}{u} \left (-du \right )=-\int \frac{1}{u} du[/tex]
Once you accomplish the integration, treating u just like you'd treat x, you replace any u in your answer with q-x.
RoshanBBQ said:
Consider
Then
Hmmm, why in this case are we deriving du/dy? instead of dy/du?
It doesn't matter which one you do (if you can do both easily). When you do a U-substitution, though, you will write
u = f(y)
So it makes sense to differentiate with respect to y. You then get du/dy = f'(y).
Ok mate, you've lost me
RoshanBBQ said:
Consider
Let
[tex]u = q-y[/tex]
Then
If:
Let
[tex]u = q-y[/tex]
then
[tex]\int \frac{1}{u}dy[/tex] right?
So why doesn't...
d = lnu y
because [itex]\int dy[/itex] = y and [itex]\int\frac{1}{u}[/itex] = ln u ?
Where is my mistake?
miniradman said:
so.
d/du = 1/u
du/dy = -1?
d/dy = 1/(q-y) x -1
d/dy = -1/q-y
Other than your abuse of notation, what you wrote is correct. So if f(y) = ln (q-y), you have that f'(y) = -1/(q-y). You can use this information to solve
$$\int\frac{1}{q-y}\,dy = \int -f'(y)\,dy = \ ?$$
miniradman said:
Ok mate, you've lost meIf:
Let
[tex]u = q-y[/tex]
then
So why doesn't...
d = lnu y
You can't integrate u with respect to y like that. You have to also substitute out the dy so that it is in terms of du. When you do this substitution, it introduces the negative sign.
When you solve for this substitution, you write
[tex]u = f(y)[/tex]
[tex]\frac{du}{dy} = f'(y)[/tex]
Now, at this point, it is important to note we are treating du/dy like division of two regular variables. In the case where f'(y) is simply a constant (here, it is -1), it is simplest to just multiply dy over and divide the constant over, resulting in
[tex]dy = \frac{du}{f'(y)}= \frac{du}{-1} = -du[/tex]
We then replace the "dy" in the original equation with "-du" since we established this equivalence. You can then integrate your 1/u with respect to u, which is important.
Maybe another example will help you see the process:
[tex]\int xe^{x^2} dx[/tex]
So the trick with u substitution is you can take out an entire f'(x)dx and replace it with a single du.
Let
[tex]u = x^2[/tex]
[tex]\frac{du}{dx} = 2x \rightarrow du = 2xdx[/tex]
We then proceed with the substitution. Let's do it slowly so you can see each effect separately. Let's put in the u first:
[tex]\int e^u xdx[/tex]
Now, if only there were a 2 in there, the 2xdx would equal du. We can do the good old fashioned constant/constant = 1 trick:
[tex]\int e^u \frac{2}{2}xdx = \frac{1}{2} \int e^u 2xdx[/tex]
We now see we have the 2xdx = du. Let's replace that now
[tex]\frac{1}{2}\int e^u du = \frac{1}{2} e^u[/tex]
Finally, we replace u = x^2. That is our original substitution.
[tex]\int xe^{x^2} dx=\frac{1}{2} e^{x^2}[/tex]
As an exercise, you could try differentiating that final equation to see it equals the original integrand.
Maybe you could try (using u substitution)
[tex]\int \frac{x^2}{x^3-1}dx[/tex]
Alright, I'll have a crack at this one...[tex]\int \frac{x^2}{x^3-1}dx[/tex]
Let u = x3-1 So:
[tex]\int \frac{x^2}{u}dx[/tex]
Then:
[itex]\int x^2 × \frac{1}{u}[/itex]
[itex]\frac{x^3}{3} × lnu[/itex]
Sub in [itex]u = x^3 -1[/itex]
Therefore
[itex]\int \frac{dy}{dx} = \frac{x^3}{3}ln x^3 -1[/itex]
It will help to look more clinically on what's on your paper:
[itex]\int \frac{x^2}{x^3-1} dx = \int \frac{x^2 dx}{x^3-1}[/itex]
Now sub [itex]x^3 -1[/itex] with [itex]u[/itex].
This means you got [itex]u = x^3 -1[/itex] and also [itex]du = 3x^2dx[/itex] which means that [itex]\frac{du}{3} = \frac{1}{3} du =x^2 dx[/itex]
Now look at your integrand, and become excited, since the right side of the equation over looks much like something in your integrand, now sub the [itex]x^2 dx[/itex] with [itex]\frac{1}{3}du[/itex] and you got:
(I'm sure you can figure out the rest from here, but I will put the rest in spoiler)
Moderator note: Even though this is just a practice problem, I removed the solution. It's against the forum rules to provide complete solutions.[/color]
Let u = x3-1 So:
Then:
Therefore
When you do U-substitution, you generally cannot have ANY of the original variable in the new integral. Integrating a term with x and u in it with respect to du (or dx) has little intuitive meaning. You must substitute it all out by using your definition of u and your definition of du/dx. Treat du/dx like a/b (two variables divided).
I follow everything up to, but not including this step.
If:
[itex]\frac{du}{dx} = 3x^2[/itex]
[itex]du = 3x^2 dx[/itex]
[itex]\frac{du}{3} = x^2 dx[/itex]
So [itex]x^2[/itex] can be replaced with [itex]\frac{du}{3}[/itex]
Do I simply sub in [itex]\frac{du}{3}[/itex] from there?
I'm not exactly sure what is meant in blue :confused:
So I shouldn't really have the [itex]-1[/itex] in there?
If:
So the red parts match
[itex]\int\frac{x^2}{u}[/itex]
Do I simply sub in [itex]\frac{du}{3}[/itex] from there?I'm not exactly sure what is meant in blue :confused:
You integrated
So you have an x^2, a u, and you're integrating with respect to a x (because of the dx). You need to have the integrand have only u and you need to integrate with respect to u (meaning du and no dx). The trick is in differentiating your substitution with respect to the variable in the original integral, e.g.
[tex]\frac{du}{dx} = 3x^2[/tex]
You can solve for du here as if it were any other variable.
And to answer your other question, yes, you replace "x^2dx" in the original integral with "du/3". You established the equivalence after all.
Which would become... [itex]du = 2x^2 dx[/itex] ?
Yes, if I hadn't made a horribly basic mistake {du/dx = 3x^2 not 2x^2}. It will be du = 3x^2dx. But with constants and substitutions, there are many games you can play. As you can see by looking at the integral at this point:
you want to get rid of a
[tex]x^2dx[/tex]
So, as Noorac showed, you can just solve for that chunk:
[tex]du = 3x^2dx \rightarrow \frac{du}{3} = x^2dx[/tex]
Now you can replace "x^2dx" in the original integral with "du/3". It is mathematically equivalent.
RoshanBBQ said:
Now you can replace "x^2dx" in the original integral with "du". It is mathematically equivalent.
:rolleyes: I thought is was [itex]\frac{du}{3}[/itex] rather than simply [itex]du[/itex] (unless that was what you meant by "du")... then:
[itex]\int\frac{\frac{du}{3}}{u}[/itex]
[itex]\int \frac{1}{u} × \frac{du}{3}[/itex]
[itex]\int \frac{1}{u} × \frac{1}{3} du[/itex]
Damn!... I'm stuck again :frown:
No that's right. I made another silly mistake, though I caught it faster this time.
Hello.
[itex]\frac{dy}{dt}=a(q-y)[/itex]
[itex]\frac{dy}{(q-y)}=adt[/itex]
[itex]\int\frac{dy}{q-y}=\int adt[/itex]
[itex]-ln|y-q|=at+c[/itex]
[itex]|y-q|=C_1e^{-at}[/itex]
y=C e-at + q
Regards.
copy + paste ... just kidding.
So do I just multiply the two fractions together and sub in the original [itex]x^3 - 1[/itex]?
You take the integral of
[tex]\int \frac{1}{u}\frac{du}{3} = \frac{1}{3} \int \frac{1}{u} du[/tex]
Remember, integrals are like summations. Just like a/3 + b/3 = (a+b)/3, in an integral, constants can be factored out of the infinite summation. So the 1/3 just comes right out. And yes, after the integration, just replace u with x^3 -1.
