Finding the Length of y = x^{3/2} from x = 0 to x = 4
  • Thread starter Thread starter Precursor
    Length
The discussion focuses on calculating the length of the curve defined by the equation y = x^{3/2} from x = 0 to x = 4 using the formula L = ∫ from a to b √(1 + (dy/dx)²) dx. The correct derivative dy/dx is 3/2 * x^{1/2}, leading to the integral L = ∫ from 0 to 4 √(1 + (9/4)x) dx. The initial calculation resulting in 64/27 was incorrect, and participants emphasized the importance of changing limits of integration when applying the substitution rule.
  • Understanding of calculus, specifically integration techniques
  • Familiarity with derivatives and their applications in arc length calculations
  • Knowledge of substitution methods in integral calculus
  • Ability to manipulate and simplify algebraic expressions
  • Study the process of calculating arc length using L = ∫ from a to b √(1 + (dy/dx)²) dx
  • Learn about the substitution method in integral calculus, including changing limits of integration
  • Explore numerical integration techniques for evaluating complex integrals
  • Practice problems involving the length of curves defined by various functions
Students studying calculus, particularly those focusing on integration and arc length, as well as educators seeking to clarify common mistakes in these calculations.
Precursor
Find the length of the curve. y = x^{3/2} from x = 0 to x = 4.
L = \int^{b}_{a} \sqrt{1 + (dy/dx)^{2}} dx
L = \int^{4}_{0} \sqrt{1 + (3x^{1/2}/2)^{2}} dx
I used substitution rule
L = 64/27
Is this correct?
Thanks
L = 64/27
Is this correct?
Thanks
http://www.wolframalpha.com/input/?i=integrate+sqrt[+1+++[+(3/2)+x^(1/2)+]^2+]+from+x=0+to+x=4
Its better to post all of your work.
Precursor said:
So my answer is wrong afterall?
By the way, thanks a lot for that website! If only I knew such a website existed before. :smile:
Yeah Its wrong.
You will face: \int_0^4 \sqrt{ 1 + \frac{9}{4}x } \;\ dx
What did you do for it?
Actually I found c(7 \sqrt{7} - 1),
where c is a numerical factor (I got 2/3) which I'm not sure of because I did the calculation sloppily.
So I suggest you show the rest of the calculation as well.
[edit] Too slow, you already have several replies. [/edit]
Ratio Test =) said:
Yeah Its wrong.
That's exactly what I got, but when I used the substitution rule, to integrate, I did not change the limits of integration to in terms of u.
Ohhh.
BTW, Its a famous mistake. :)
  • · Replies 105 ·
  • · Replies 25 ·
  • · Replies 20 ·
