Finding the Limit of a Function as x Approaches Negative Infinity
  • Level: Undergrad
  • Thread starter Thread starter John O' Meara
    Negative
3 replies · 2K views
John O' Meara
Find a negative number N such that [tex]|\frac{x^2}{1+x^2}-1| < \epsilon[/tex] for x < N. That implies [tex]|\frac{-1}{1+x^2}| < \epsilon if x < N[/tex].This gives me the following [tex]-|\frac{1}{1+x^2}| < \epsilon if x < N[/tex].I do not know what to do from here. Please help as I am teaching myself. Thanks.
Finding "a negative number N such that if x< N then ..." is very peculiar. But since x only occurs to even power, it doesn't matter whether you use x or -x. "Find a positive number M such that if x> N then [itex]|\frac{-1}{1+x^2}|< epsilon[/itex]" is more "standard" and gives N= -M. Saying that [itex]|\frac{-1}{1+x^2}|< \epsilon[/itex] is the same as saying [itex]0< \frac{1}{1+x^2}< \epsilon[/itex] which is, in turn, the same as saying that [itex]1+ x^2> \frac{1}{\epsilon}[/itex] which is the same as [itex]x^2> \frac{1}{\epsilon}- 1[/itex]. Can you carry on from there?
[tex]x=+/-\sqrt{\frac{1-\epsilon}{\epsilon}}[/tex] Then I have to determine which one of the roots is the answer, as x is negitive it must [tex]-\sqrt{\frac{1-\epsilon}{\epsilon}}[/tex], but that last answer doesn't sound a very good reason as to why it is the negitive root. I was wondering is there better reasoning?
The definition I am using is: Let f(x) be defined for all x in some infinite open interval extending in the negative x-direction. We will write
[tex]\lim_{x-> -\infty}f(x)=L[/tex]
if given any number [tex]\epsilon >0[/tex], there corresponds a negative number N such that
[tex]|f(x)-L| < \epsilon \mbox{ if } x < N[/tex].
