Finding the limit without L'Hôpital's rule
The limit to prove is that as n approaches infinity, (1 - 1/n^2)^n converges to 1. The discussion emphasizes the relevance of the limit of (1 + 1/n)^n, which is bounded above by e, as a foundational concept. Participants suggest using the generalized binomial theorem and the squeeze theorem to show that all terms except the first vanish in the limit. Understanding why (1 + 1/n)^n equals e is deemed crucial for solving the problem at hand. Ultimately, these insights guide the approach to proving the desired limit without L'Hôpital's rule.
Unredeemed
Required to prove that
<br /> \displaystyle\lim_{n\rightarrow \infty} ((1 - \frac{1}{n^2})^{n}) = 1<br />
\displaystyle\lim_{n\rightarrow \infty} ((1 + \frac{1}{n})^{n}) is bounded above by e. I'm not sure if this is relevant, but it was the first part of the question, so I'd assume so?
Also, we haven't proved L'Hopital's rule yet, so I can't use that.
I was thinking to maybe try and write it in a similar way to the first part.
So: <br /> \displaystyle\lim_{n\rightarrow \infty} (((1 + \frac{1}{-(n^2)})^{-(n^2)})^{\frac{-1}{n}})<br />
But, as n tends to infinity -n^2 tends to negative infinity?
Try the generalised binomial theorem. If you want to prove rigorously that all the terms except the first go to zero at the limit, use the squeeze theorem.
yes, it is relevant...firstly, u should understand why \displaystyle\lim_{n\rightarrow \infty} ((1 + \frac{1}{n})^{n}) = e then u can solve this question easily..
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
