Finding the magnetic flux from a 3 Dimensional Shape
10 replies · 3K views
Vladi
In Fig. 32-9 there is a + x-directed uniform magnetic field of 0.2 T filling the space. Find the magnetic flux through each face of the box shown.
ΦM = B ⊥ A = BA cos θ
My attempt is attached to this post. How do I determine which faces have magnetic flux? I assumed it was only the faces that are perpendicular to the magnetic field, but my books key says otherwise. Thank your for your time.
OK. As you calculated correctly, there is flux through the sloping face even though that face is not perpendicular to the field.
I guess you rounded each answer to only 1 significant figure since the data is given to only one significant figure. OK.
Are you supposed to consider the sign of the flux? The entire surface of the box is a closed surface. The usual convention is that flux is considered negative wherever the flux enters a closed region and positive where it exits. With this sign convention, the total flux through a closed surface should be zero when the field is uniform.
If the total flux is zero, does this mean that the surface must be closed and have only one kind of shape(triangle, rectangle, etc)? If this were true, the top face would be equal to zero, but it ain't. Doesn't this imply there are three conditions to consider when you are deciding if the total flux is zero? The surface must be closed, have only one kind of shape, and can't be inclined? If these three conditions hold true, I would say that the back, bottom, and front face is equal to zero. Correct me if I'm wrong.
A "closed surface" is a surface that completely encloses a volume of space. The 6 faces of your box, all together, make a closed surface; i.e., they completely enclose a volume of space (the inside of the box). An individual face, such as the top of the box, does not represent a closed surface. A closed surface can have any shape as long as it completely encloses a volume. The surface of a balloon is a closed surface even if you deform the shape of the surface by squeezing the balloon.
For any closed surface, no matter what it's shape, the total flux through the entire surface will be zero for a uniform field. This assumes that you adopt the sign convention for flux mentioned earlier. (The flux through a closed surface might be zero even if the field is not uniform, but you'll learn the conditions for that when you cover Gauss' law.)
So, the total flux for the entire surface of your box should be zero if you consider the signs of the flux for the individual faces. As a check of your work, you can see if you get a total flux of zero.
Your previous reply cleared many of my misconceptions. What about the bottom and the sides? Do I ignore them? They aren't perpendicular to the magnetic field and I don't understand how flux can enter or exit them. Should I think of a flash light when I solve such problems? If I point a flashlight in the positive x direction, the top region and the front region would cast a shadow. The back, sides, and the bottom would be bright.
The sum of flux is close to zero. Does this look good? Or do I have a sign error? Thank you for your time.
In your first post you said the flux through the bottom and the flux through the front and back trapezoidal sides are zero. That's correct. But now you are calculating them to be nonzero. Why the change?
I don't believe you calculated the areas correctly for the bottom or the trapezoidal sides. But the values of these areas don't matter since the flux is zero due to the orientation of these faces.
I think I finally got it. The flux entering a closed region is negative. The flux exiting a closed region is positive. The front,back, and bottom regions are zero because no flux is entering or exiting these regions. The sum of the entering and exiting fluxes is zero.
Yes, that's it. Good.
Keep in mind that this is a special case where you have a uniform E field. When the field is nonuniform, the total flux through a closed surface could be zero or nonzero.
I will. Thank you for all your help.
Just realized that you are dealing with a B field, not an E field. But the idea is the same.
