Finding the mass of a particle, when its charge is known
The discussion centers on calculating the mass of a latex sphere suspended between metal plates, where the electric force balances the gravitational force. The electric force is given as 3.6 × 10^−14 N, which equals the weight of the sphere. To find the mass, one must relate weight to mass using the equation weight = mass × gravity. Participants clarify that the mass can be found by dividing the electric force by the acceleration due to gravity (approximately 9.8 m/s²). The correct mass of the sphere is determined to be 3.7 × 10^-15 kg.
bobsmith76
A small latex sphere experiences an electric force of 3.6 × 10^−14 N when suspended halfway between a pair of large metal plates, which are separated by 48.0 mm. There is just enough electric force to balance the force of gravity on the sphere.
(a) What is the mass of the sphere?
q = (mgΔd)/V
F (electrostatic force) = kq/r^2
I have two unknowns in my first equation, q and V. My attempt to find q fails because I get a number that is around 10^-27. So if my number for q is wrong, then my number for V will also be wrong.
q = (mgΔd)/V
I assume that's just the first part of the question, because it's actually very simple. You're given the electric force and told that it exactly balances the gravitational force (which is the weight). So in essence, you're told the weight of the sphere. How do you relate weight to the mass?
Ok, I multiplied 3.7 * 10^-15 by 9.8 and got the correct answer. Thanks.
bobsmith76 said:
My book says the answer is 3.7 * 10^-15. I don't see how they get that.
I repeat (from my earlier post):
Sure, but to go the "right way" (to get the mass given the weight), you must divide by g (which is close to 9.8ms^{-2}.
