Finding the mass of two planets
  • Thread starter Thread starter prlion16
    Mass Planets
The discussion revolves around calculating the mass difference between two planets based on the weight of a robot on each planet. The robot's mass is 5720 kg, and it weighs 3720 N more on planet A than on planet B. The radius of both planets is given as 1.33x10^7 m. The participants are struggling with applying the gravitational force formula and setting up the system of equations needed to find the mass difference. The key points include understanding the relationship between weight, mass, and gravitational force at the surface of the planets.
prlion16
Ok well, I have used up 2 out of 3 of my submissions for this question. I have tried to do a system of equations and failed twice. I really don't even know where to start so I was hoping that you guys could help me.
The problem is.
The mass of a robot is 5720 kg. This robot weighs 3720 N more on planet A than it does on planet B. Both planets have the same radius of 1.33x10^7 m. What is the difference MA - MB in the masses of these planets?
Thank you.
Use the defintion of weight. Assume that it's evaluated at the surface of the planets.
ok... I still don't get what I am supposed to do. Sorry. I get that weight is going to be calculated at the surface of the planets so d=1.33x10^7. I got the equation F=6.67x10^-11(5720m1/((1.33x10^7)^2)). I really just don't get what I am supposed to do after this.
You are provided with the difference in weight (of the robot), right?
For planet B it is 5720a and Planet A is 5720a+3720. right?
WA - WB = Gm(MA-MB)/d2
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
