Finding the modulus and argument of ##\dfrac{a}{(b±ci)^n}##
  • Thread starter Thread starter chwala
17 replies · 3K views
chwala
Finding the modulus and argument of complex numbers of the form ##\dfrac{a}{(b±ci)^n}## where ##a,b,c,n ∈ \mathbb{Z}##
complex numbers
Doing a refreshing on this, let me come up with my own example,
Finding the modulus and argument of ##\dfrac{4}{(1-i)^3}##,
Considering the denominator,
Let ##z=1-i, |z|=\sqrt 2→ z^3=\sqrt 2⋅ \sqrt 2⋅\sqrt 2 = 2\sqrt 2##, noting that ##arg z_1z_2=arg z_1 + arg z_2##, then
argument ##z= -\dfrac{π}{4}-\dfrac{π}{4}-\dfrac{π}{4}=-\dfrac{3π}{4}##.
Considering the numerator,
modulus=4, argument = 0.
Now having both numerator and denominator in mind, and noting that modulus,
##\left|\dfrac{z_1}{z_2}\right|=\dfrac{|z_1|}{|z_2|}##
##\left|\dfrac{4}{2\sqrt2}\right|=\dfrac{|4|}{|2\sqrt2|}=\dfrac{2\sqrt2}{2}=\sqrt 2##
argument ##Z= \left[0-\dfrac{3π}{4}\right]=\dfrac{3π}{4}##.
The steps seem clear and quite easy, question is does this apply to all forms i.e ##\dfrac{a}{(b±ci)^n}##? or are there cases where this fails.
on Phys.org
chwala said:
Doing a refreshing on this, let me come up with an example, Finding the modulus and argument of ##\dfrac{4}{(1-i)^2}##,
i let ##z=1-i, |z|=\sqrt 2→ z^3=\sqrt 2⋅ \sqrt 2⋅\sqrt 2 = 2\sqrt 2##, noting that ##arg z_1z_2=arg z_1 + arg z_2##
Why do you have ##z^3##?
Isn't ##\left|\frac 4 {(1 - i)^2}\right| = \frac 4 2 = 2##?
To find arg of your example, you could multiply out the ##(1 - i)^2## factor to get -2i, so then you have ##\frac 4 {-2i}## (assuming my mental arithmetic is good), then rationalize that to get a complex number in the form of m + ni. You can find the angle this makes in a straightforward manner.
amended ...typo.
If you get my thinking, I am looking at, say, ##\dfrac{100}{(13-15i)^{49}}## large numbers, you cannot multiply the complex number by way of expanding. The approach I used may be faster, I stand to be corrected.
From your revised post #1:
chwala said:
Considering the denominator, Let ##z=1-i, |z|=\sqrt 2→ z^3=\sqrt 2⋅ \sqrt 2⋅\sqrt 2 = 2\sqrt 2##, noting that ##arg z_1z_2=arg z_1 + arg z_2##, then
You'd have to convince me that this is a valid step; i.e., that, say ##arg(\frac a {b + ci}) = arg(b + ci)##.
For example, is ##arg(\frac 1 {1 + i}) = arg(1 + i)##?
Reply
this should be, ##arg(\frac 1 {1 + i}) = arg1 - arg(1 + i)##.
Using,
##arg \left(\dfrac{z_1}{z_2}\right)=arg z_1 -arg z_2##.
polar, dude... polar
Granted, I'm more engineer than mathematician. I'll always take the easy path.
Reply
  • Haha
WWGD said:
And ##arg(z1+z2)\neq argz1+argz2. ##. You need to consider the " overflow" issues.
@chwala is not asserting this -- only that ##arg(z_1z_2) = arg(z_1) + arg(z_2)## or that ##arg\left(\frac{z_1}{z_2}\right) = arg(z_1) - arg(z_2)##
Where is this line coming from? i do not think i stated this anywhere.
Reply
Ibix said:
I agree with @DaveE. Use ##z=|z|e^{i\mathrm{arg}(z)}##. Job done two or three lines later.
Interesting approach,
##1-i=\sqrt 2 e^{\dfrac{-πi}{4}}##
##(1-i)^3=2\sqrt 2 e^{\dfrac{-3πi}{4}}##
##\dfrac{4}{(1-i)^3}=\dfrac{4}{2\sqrt 2e^\dfrac{-3πi}{4} }={\sqrt 2e^\dfrac{3πi}{4} }##
Ok, my bad. But the issue with the overflow remains: ##arg(z1z2)=arg(z1)+arg(z2)## only if the sum is less than ##2 \pi ##.
Reply
It would be good to answer the original question.
$$ z=\frac{a}{(b\pm ci)^n}=|z|e^{i\arg(z)} $$.
What are ## |z| ## and ## \arg(z) ## in the general case?
@Gavran i hope i am getting you right, are you asking a question? i thought i had already addressed the modulus and argument in posts ##1## and ##12##.
chwala said:
i thought i had already addressed the modulus and argument in posts 1 and 12.
No, not for the general expression. You worked on the example you gave in post #1 : ##\dfrac 4 {(1 - i)^3}##.
Reply
aaaaaah okay,
in polar form, ##b+ci=re^{iθ} ##
##(b+ci)^n = r^n e^{inθ} ##
##z=\dfrac{ae^{-inθ}}{r^n}=\dfrac{ae^{-in\tan^{-1}\left(\frac{c}{b}\right)}}{(b^2+c^2)^\frac{n}{2}}##
Modulus: ##\dfrac{a}{(b^2+c^2)^\frac{n}{2}}##
Argument: ##{-n\tan^{-1}\left(\dfrac{c}{b}\right)}##
Reply
Good. I think that's a good place to stop. Everyone knows what you mean by ##−n ~ tan^{−1}(c/b).##
But, a rather pedantic and nitpicking extension: Your solution could result in ##\theta=-\frac{17\pi}{4}## in some case. Most would rather think of this as ##\theta=-\frac{\pi}{4}##. Also, the argument for ##b, c >0## isn't the same as for ##b, c <0##, but ##tan^{-1}(c/b)## is the same.
So there is an issue with the principle branch of ##tan^{−1}##, ##arg(z)##, ##Arg(z)##, etc.
https://math.libretexts.org/Bookshelves/Analysis/Complex_Variables_with_Applications_(Orloff)/01:_Complex_Algebra_and_the_Complex_Plane/1.09:_The_function_arg(z)#:~:text=The branch −π<arg(,branch of arg(z).
Reply
