- 2
- TL;DR Summary
- So I'm basically doing an experiment where I am going to add different amounts of acid and base in order to change the pH of slime. ( I heard putting acid and base causes the forming and breaking of bonds inside the slime)
How would I be able to calculate the pH of slime?
I learned how to "add" pH's, like I know how to get a new pH from adding one solution to another.
But I'm not sure on how to calculate the pH of slime.
From what i know so far, this is all I will be making to make the slime:
(Poly – Vinyl Alcohol (PVA), water, Tetraborate Na2B4O7 , and deonized water)
Do I need to figure out how much the molarity and amount of all these substances I'm going to use and calculate the pH??
I'm trying to experiment the viscosity of the slime as I put different concentrations of acid and base in the slime.
The ultimate goal I'm trying to get is to see the relationship between pH and viscosity.
(I will be putting slime inside a graduated cylinder, drop a ball inside it, and use the viscosity equation (viscosity = [2(ps-pl)ga2]/9v))
++also will I be able to increase the pH of the slime by simply just adding more of the same pH of base? or would I have to change the pH of base every time.
