Finding the radius of convergence
The discussion centers on finding the radius of convergence for a given series using the ratio test. Initially, there was confusion about the correct expression for the series, leading to an incorrect assumption about the radius being 1/4. Upon reevaluation, it was clarified that the series involves factorials in both the numerator and denominator, specifically (n!)^2 in the denominator. Participants emphasized the importance of ensuring the series is correctly identified before applying the ratio test. The conversation concludes with a realization that the numerator sequence follows a pattern of even factorials.
Timebomb3750
Finding the radius of convergence...
1+2x+(4x^(2)/2!)+(8x^(3)/3!)+(16x^(4)/4!)+(32x^(5)/5!)+...
I would use the ratio test. Which is...
lim as n→∞ (An+1/An)
I know what to do to find the answer, but I don't know how to find the expression for the provided series.
I'm guessing it's ((2x^(n))/n!), then work with the ratio test from there?
First, I assume you mean ((2x)^n)/n!. That IS correct. Use the ratio test from here. Remember that the ratio has to be less than 1 (as n goes to infinity) for the series to converge. That should help you out.
Sweet. I was right on the expression. Okay, so I did the ratio test.
(2x^(n+1))/((n+1)!) * (n!/2x^(n)) = ((xn!)/(n+1)!) But doesn't this lim as n→∞ of this equal 0? Or is there more simplification I need to do? The answer is (1/4), but I don't see how I'm going to get that.
First, the ratio test gives zero, i.e. less than 1 for any x you choose, so what does that tell you about the radius?
1/4 is definitely not the correct answer for this function. I checked that two different ways, and they gave me the same answer... and it wasn't 1/4.
Odd. Because the textbook says the answer to this is (1/4). Well. I should double check to see if my expression agrees with the given series.
Oops! Wow. I was doing the wrong problem.
The series is 1+2x+((4!x^(2))/(2!))+((6!x^(3))/((3!^(2))+...
Sorry. Okay. I know the denominator of the expression is going to be (n!)^2, but not so sure of the numerator. Other than that, I probably can handle the rest of the problem.
How do I edit posts? I keep typing the series wrong...
Forget it. Delete this. I'll just make a new thread asking for help on finding the series. I'll be sure to type out the series correctly this time. Sorry. I feel so stupid.
No need to worry I figured out what you meant. The denominator is (n!)^2, like you said. The numerator isn't that hard, either, actually. Just think about what sequence goes 0!, 2!, 4!, 6!.
