Finding the restoring force, Hooke's Law
Hooke's Law is applied to determine the spring constant of a light spring with an unstretched length of 35.0 cm, which becomes 41.5 cm when a 7.50 kg weight is hung from it, resulting in a spring constant of 1130 N/m. When two people pull on the spring with equal forces of 190 N in opposite directions, the net force is zero, but the spring still stretches due to the applied forces. The total force exerted on the spring is the sum of the individual forces, leading to an extension based on the spring constant. The spring constant remains unchanged regardless of the direction of the forces applied. Understanding these principles clarifies how to calculate the restoring force and the resulting length of the spring under different conditions.
h8ligan
Hooke's law describes a certain light spring of unstretched length 35.0cm. When one end is attached to the top of a door frame and a 7.50kg object is hung from the other end, the length of the spring is 41.5cm. a) Find its spring constant. b)The load and spring are taken down. Two people pull in opposite directions on the ends of the spring, each with a force of 190N. Find the length of the spring in this situation.
F=-kx
I found the spring constant in a) and it was 1130N/m which I am unsure if it is the same for b. The real problem is I can't figure out how I am supposed to find the restoring force. My thoughts seem to think that because they are pulling in opposite directions at the same force then the net force would be zero and therefore so would the restoring force?
Imagine pulling on a spring attached to a wall. Now imagine pulling on the spring in part B.
Ok so then it would stretch, and would be double? What about the spring constant would it remain the same?
For the purposes of what we're doing, the spring constant is always constant.
If one pulls on a mounted spring, the spring has a force f=kx. If two people pull on the spring there are now two forces. f1+f2=kx.
Okay, thank you I believe I got it :)
