Finding the Right Software for Building Energy Simulation
Several software options for building energy simulation are discussed, including CHVC and Carrier, with a recommendation to search for "HVAC load calculation software" for more choices. Users emphasize the importance of customizable features, such as wall thickness, insulation, and material layers, to accurately calculate heating and cooling needs. Specific instructions for modifying wall properties in CHVC are provided, including switching to metric units and accessing the wall builder feature. The conversation highlights the necessity of professional-grade software for detailed energy analysis, which often comes with a higher cost. Overall, the discussion focuses on finding effective tools for precise energy simulation in building design.
TSN79
Does anyone know any good software to calculate the need for cooling/heating and such in builidings? One where I can change properties of almost every building aspect, such as wall-thickness, insulation, sun conditions, windows, outside temp, inside temp, and so on to find the energy needed to keep a specific temp inside while the outside conditions are such and such.
I use CHVC: www.elitesoft.com
I've heard Carrier has a decent one too. Do a Google for "hvac load calculation software" and you'll get several more. Be aware, though, that most of these are professional products and generally have professional pricetags.
Ah, excellent, I've used this one. Then you might be able to answer this question: how to I change the thickness of walls? And also, I would like to use custom walls, floors and ceilings, since the preset choices are US standards which don't tell me ****, but I'm not sure how to "design" a custom let's say wall with insulation thickness, and other layers of material that might be in it. Any suggestions?
I'll give you a walkthrough at work tomorrow...
Likes Kissboy
As long as it is possible I'm satisfied, but a walkthrough would be nice :-)
Well, first off, in the General Project Data ("G" button in the toolbar), there is an option for switching to Metric units. Then in the "Master" menu ("M" button in the toolbar), there is a tab for roofs, walls, and partitions. Under "walls", there are four drop-down menus. The one on the left brings up a box allowing you to build your own. The second one gives common wall types (it's what I usually use). The third one gives a calculator similar to the wall builder in the first tab.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
