High School Finding the smallest positive solution to trig equation
  • Thread starter Thread starter Mr Davis 97
    Positive Trig
The equation sin(3x) = cos(7x) leads to the conclusion that the smallest positive solution is x = 9 degrees. This is derived from the relationship that sin and cos are equal when their arguments are complementary, specifically 3x + 7x = 90 degrees. To confirm that this is the smallest solution, one must consider the periodic nature of sine and cosine functions, where additional solutions can be generated by adding multiples of 180n degrees. Graphical representation of y = sin(3x) and y = cos(7x) further validates that x = 9 is indeed the smallest positive solution.
  • Understanding of trigonometric identities
  • Knowledge of sine and cosine functions
  • Familiarity with periodic functions and their properties
  • Ability to manipulate and solve equations involving angles
  • Study the properties of sine and cosine functions in detail
  • Learn about solving trigonometric equations using identities
  • Explore graphical methods for solving trigonometric equations
  • Investigate the implications of periodicity in trigonometric functions
Mathematics students, educators, and anyone interested in solving trigonometric equations or enhancing their understanding of periodic functions.
Mr Davis 97
I have the equation ##\sin 3x = \cos 7x##, and, in degrees, I have to find the smallest positive solution.
Immediately, we can see that sin and cos are equal if their arguments are complements, so ##3x + 7x = 90##, which means that ##x = 9##.
I know that that is a correct solution, but how do I show that it is, in fact, the smallest positive solution?
Likes Charles Link
Mathematics news on Phys.org
I would do it this way:
sin(x)=cos(x) if x=45 degrees. Of course, you knew that and could then get the correct solution. However, you are missing one part -- x=45+180n degrees where n is an integer. If you are looking for the smallest possible x, n would have to be zero.
An interesting problem. Since the angles are both in the first quadrant, I think you clearly have the smallest x. To prove it might take a little work, but it would take more effort to find the second smallest or 3rd smallest. (Solving the equivalent ## \sin(3x)=\sin(90-7x) ##, trigonometric identities allow 360 degrees to be input into either side and you have essentially the same equation ) e.g. If ## 3x=360+(90-7x) ## so that ## 10x=450 ## then x=## 45 ##. I found another solution, but is it the second smallest? editing... You can also add 720 or other multiples of 360 to either side, or you can do ## 180-\theta ## to either term inside the sine function without changing the equation...
A follow-on to post #3: Overlaying a graph of y =sin(3x) and a graph of y=cos(7x) is perhaps the quickest way to see the (approximate) solutions of this problem. It will show you that your x=9 is the smallest x.
  • · Replies 19 ·
  • · Replies 52 ·
