Finding the Speed and Direction of a Woman on a Moving Ship
  • Thread starter Thread starter dGasim
    Relative Vectors
The problem involves determining the speed and direction of a woman walking on a moving ship, with the woman walking due west at 3 mi/h while the ship moves north at 23 mi/h. The task is to find the woman's speed and direction relative to the water's surface.
  • Mixed
  • Participants discuss the use of vector addition for relative velocity and explore the correct application of the formula. There is an attempt to calculate the resultant speed using the Pythagorean theorem and to determine the angle using arctan.
Some participants have provided guidance on the use of vector addition and the calculation of angles. There is acknowledgment of the need to express the direction in a specific format, and participants are exploring how to articulate the angle in relation to cardinal directions.
Participants note the requirement to express the direction as "N _____ W," which adds a layer of complexity to the problem. There is also mention of potential confusion regarding the angle's interpretation based on the calculator's mode.
dGasim
A woman walks due west on the deck of a ship at 3 mi/h. The ship is moving north at a speed of 23 mi/h. Find the speed and direction of the woman relative to the surface of the water. (Round your answers to one decimal place.)
First I drew the picture:
EDIT: Attachment
Then I solved the relative velocity formula:
[itex]v_{w/g} = v_{s/g} + v_{w/s}[/itex] = 23 + 3 = 26mi/h
Which went wrong, so I made another attempt:
[itex]\sqrt{23^2 + 3^2} = 23.2[/itex]
And i don't know how to find the angle. Should I do it like arctan(23/3) ?
Thanks in advance,
Gasim Gasimzada
Hi Gasim! :wink:
Your formula is correct :smile:, but of course it's a vector formula, so you must always use vector addition (so your second try is the correct one).
Yes, use arctan. :smile:
EDIT: Attachment
Since the vectors aren't in the same direction, you can't simply add their magnitudes.
This is fine.
Yes. Depending on the mode your calculator is in, you'll get an answer in degrees or radians. To answer the question of the problem, you will probably need to say something like "10 degrees north of west" or "at a heading of 280 degrees." These are just examples, though.
dGasim said:
Thanks in advance,
Gasim Gasimzada
I have gotten the first part of the question right. But when it comes to second one. I did arctan(23/3) which gave me 82.6*. But I am not sure of the direction in this case because the question wants the input as "direction N _____ *W"
btw. * = degrees in this case.
Hi Gasim! :smile:
(have a degree: ° :wink:)
dGasim said:
… "direction N _____ *W" …
the number you have to fill in is the number of degrees from North to the direction …
the direction is that number of degrees West of North :wink:
Thanks a lot! Got every question right because of you guys! :)
