erobz
- 1,849
I think it’s says high strain rates are more Hookean in behavior. You should also notice that the forces developed are higher per unit deflection under higher strain rate. What is the initial strain rate for a 30 ft rope at 5 mph, vs 15 mph. How much do the curves change for your rope?B0B said:From the cited PDF
I read that as shock loads, aka, high speed loads from a vehicle going 15 MPH yanking on a vehicle in mud is more elastic with better recovery than slow speed loads (aka, my testing approach with a winch). Am I reading that right?
Also, the higher strain rate curves end more abruptly without plastic deformation. So you can get higher loads, but if they snap they are releasing that energy abruptly too. The higher the load the more likely something on the vehicle could fail possibly sending something through a vehicle of the unsuspecting parties involved like in that tragic story you shared.
The question I have is how are you planning to use this info? Ideally you would use it as a type of safety factor, but when that truck doesn’t come out of the mud it could ( not saying you would) be used as a “push the limits factor” instead; which is less desirable for concerns of safety...IMO.
