Oblivion77
- 113
- 0
Here is the problem
Sum of the forces in x, y and moments
I am having troubles drawing a good FBD.
Doc Al said:What forces act on the rod?
Hint: Find the spring stretch as a function of angle.
Doc Al said:Which way do "normals" usually act?![]()
Doc Al said:Yep. You should have a good handle on that FBD now.
The unstretched length of the spring is unknown and unneeded. What you do need is how much the spring is stretched when the bar is at an angle. When the bar is vertical the spring is unstretched, thus the the amount of stretch is zero.Oblivion77 said:I am having some trouble seeing the stretched and un-stretched lengths of the spring. When the bar is vertical it looks like the un-stretched length is 0.
Something like that--but not that.Oblivion77 said:Is it something like 5sinα?
No, it's the height of the spring end measured from the horizontal fixed bar. Compare that to where the spring was when the angled bar was vertical (and the spring unstretched). The difference in height will tell you the amount the spring was stretched.Oblivion77 said:So is 5Cosα the stretched?
You need L-Lo, but not Lo.Oblivion77 said:I know F=k(L-Lo). but earlier you said the un-stretched length was not needed.
Doc Al said:You need L-Lo, but not Lo.
Do this. Find the height of spring end above the fixed horizontal bar when the 5m bar is vertical. (That should be easy!) Then find its height when the 5m bar is at an angle. (You've already done that.) The difference between those two heights is the amount of stretch in the spring (which is all that L-Lo is) when the bar moves from vertical to some angle.
