Finding the time when velocity equals a target value given v = e^t
  • Context: Undergrad
  • Thread starter Thread starter spam_hammer
    Velocity
7 replies · 4K views
spam_hammer
Hi all,
This is my first post so I hope this doesn't break any rules, to the best of my knowledge it doesnt, but let me know.
i am curently revising for a maths exam and i am practising questions on velocity.
how should i go about calculating a questoin in the form
v= e^t
at what value of t does the particle have a velocity of x ?
I have removed the numbers so that you guys arent answering the actual question for me. I am unsure if the question can still be answered as i have written it , if not i will post the actual figures.
also just to check an answer I have calculated ( I think):
find the acceleration of a particle whose velocity v=e^3t-2 at t=1
My answer acceleration T= 1 m/s^2
thanks
For the first question, if v denotes velocity, then you have v = e^t. You want to know when v, or e^t, is equal to x. So you have x = e^t. Use the natural logarithm to solve for t.
For your second question, your answer is wrong. If v = e^(3t) - 2, then you know that the acceleration = dv/dt. Calculate dv/dt at t = 1.
okay so dv/dt at t=1
v=e3t-2 t=1 so v= e1
differentiation = 1e0= 1
I'm afraid I am a maths dunce so i can't see where i went wrong
I am unsure how to use ln here?
apologies for my simpleness of mind :P
v = e^(3t - 2)
Differentiate using the chain rule. Then just plug in 1 wherever you see t.
For the second question if x = e^t, then ln(x) = ln(e^t) = tln(e)?
What's ln(e) equal to?
i am going to say, tentatively, 1 ?
v = e^(3t-2)
First take the derivative, then plug in t=1.
dv/dt = 3e^(3t-2) (chain rule)
t=1
dv/dt = 3e
v=e^t
ln v = lne^t = tlne = t
So: t = lnv
Evening all,
another day, another revision question in the endless battle against my brain to make it understand chain rule.
this time I think I have worked through it and would much apreciate it if someone would notify me of the myrriad mistakes with which it is ridden i am sure.
okay question :
The velocity v in m s-1 of a moving body at time tseconds is given by v=e2t-1 when t=0.5 displacement equals 10m. Find the displacement when t=1
My workings :
Chain rule v= eu where u= 2t-1
intergrate 2t-1 = t2-1t+c
when t = 0.5 displacement (a) = 10
Then using this to find out value for c:
((0.5)2-0.5+c) *e 2(0.5)-1=10
(-0.25+c)*e0=10
(-0.25+c)* 1 = 10
-0.25= 10 -c
-10.25= c
substituiting this information back into the question
a=((1)2 - 1(1) -10.25)* e 2(1)-1
-0.25 * e = -27.9
the first thing that makes me think i am wrong is the negative value for displacement .
Im not sure if any of this even makes sense. please let me know
spam_hammer said:
Evening all,
okay question :
The velocity v in m s-1 of a moving body at time tseconds is given by v=e2t-1 when t=0.5 displacement equals 10m. Find the displacement when t=1My workings :
Chain rule v= eu where u= 2t-1intergrate 2t-1 = t2-1t+c
Looks like you have to calculate the definite integral!
The anti-derivative of e2t-1 is (1/2)e2t-1.
You probably don't understand why, so that's why I'll explain. If you take the derivative of, say: eax, the derivative is aeax (chain rule- a is the derivative of ax). When you take the anti-derivative, you have to 'undo' this extra factor a that comes up front, so you divide by it. Suppose we have again eax, the anti-derivative will be (1/a)eax, because if we differentiate it again we get back to eax.
So what you have to calculate is:
int01[(1/2)e2t-1] dt
Remember that you don't have to find the constant when taking a definite integral (this makes physical sense as well; it only matters how much distance has been traveled in the time interval from 0 to 1, not how much had been traveled before or after, which would basically be the meaning of having a constant in this case. Hope this doesn't confuse you. Forget about it if you don't get it )
