Finding Torque and Half Rated Torque in DC Shunt Motors
  • Context: Engineering
  • Thread starter Thread starter Joe85
    Dc Motor Shunt
This discussion focuses on calculating torque and half-rated torque in DC shunt motors, specifically using the equations for back EMF and armature current. Given parameters include a supply voltage of 500V, full load armature current of 45A, and armature resistance of 0.3Ω. The calculations reveal that at half load, the armature current is 21.3635A, resulting in a speed of 608 RPM and an efficiency of 80%. Additionally, the impact of increasing field resistance on torque and speed is analyzed, confirming that reduced flux leads to increased speed and necessitates higher armature current to maintain torque.
  • Understanding of DC shunt motor principles
  • Familiarity with electrical circuit equations
  • Knowledge of back EMF calculations
  • Proficiency in torque and efficiency calculations
  • Study the relationship between field current and torque in DC motors
  • Learn about the effects of armature resistance on motor performance
  • Explore the implications of varying field resistance on speed and torque
  • Investigate advanced torque calculation methods in electric motors
Electrical engineers, students studying motor control, and professionals involved in the design and optimization of DC shunt motors will benefit from this discussion.
Joe85
Hi All, I'm struggling a little bit with the last part of the question and would really appreciate a bit of help on how best to approach and solve. I've written below what i think is the answer but it just doesnt feel right to me so would be grateful for some guidnance.
i) A 20 kW, 500 V d.c. shunt wound motor draws a current of 45A when running at full load with a speed of 600 rev min–1. On no load, the current drawn from the supply is 5 A. If the armature resistanceis 0.3Ω and the shunt field resistance is 220Ω, calculate the armature current, speed and efficiency of the motor when the torque falls to half of its full load value, assuming that the flux per pole doesnot change.(Hint: don’t forget that all armature current is supplying torque. Onemust decide at some points what is the armature current producingtorque and at others, to determine generator emfs, the total armaturecurrent).
(ii) State what you would expect to happen to the speed if a resistance isinserted into the field circuit.
(iii) If a resistance of 50 Ωis inserted in series with the shunt field,calculate the armature current required to maintain half full-loadtorque. Calculate also the speed of the motor when supplying this torque.
Below:
Homework Equations:
E=V-IaRa
n2 = (n1×E2)/E1
If = V/Rf
V×Ia
T∝ΦIa
E∝ΦN
i)
V = 500v, N1 = 600RPM, It = 45A, Rf = 220Ω, Ra = 0.3Ω
It = Ia + If
If = V/Rf = 500/220 = 2.273A
Ia = It - If = 45 - 2.273 = 42.727A
Now: T∝ΦIa and if the flux per pole is constant then T∝Ia
So Ia when the Torque falls to half it's full load value is: Ia/2 = 42.727/2 = 21.3635A.
Since n2 = (n1×E2)/E1, we will need to find the back EMF at full load and half load.
E1=V-IaFLRa
∴ E1 = 500 - (42.727×0.3) = 487.182v
E2=V-IaHLRa
∴ E2 = 500 - (21.3635×0.3) = 493.591v
n2 = (600x493.591)/ 487.182 = 608RPM.
Total Power at Half Torque :
PHL = VIaHL = 500×21.3635 = 10681.75 Watts
Total Power at No Load:
PNL = VIaNL = 500×5 = 2500 WattsField Loss:
Pf = If2Rf = 2.273 × 220 = 1136.64 Watts
Fixed Loss:
2500 - 1136.64 = 1363.36
Armature Loss:
Pa = Ia2Ra = 21.3635 × 0.3 = 136.92 Watts
10684.75/(10681.75+2500+136.92 = 0.80 = 80%
Speed = 608RPM, Ia = 21.3635, Effeciency = 80%
ii)
An increase in field resistance would result in the in the reduction of current flowing in the field circuit and thus a reduction in flux. Since speed is inversely proportional to flux, if the flux is reduced the speed will increase. And since T∝ΦIa, the armature current will need to increase to maintain the same Torque output to compensate for the reduction in flux.
iii)
This is where i have hit a brick wall. I'm not sure how to find the torque or the half rated torque to begin solving this problem. Would appreciate nudge in the right direction.Thanks,
Joe.
For solving iii), use your reasoning for part ii).
What is the half load armature current before adding extra field resistance?
Thanks.
IaHL=21.3635A?
If we add the resistance to the the field circuit then:
Rf=270Ω and If=500/270 = 1.852A.
If It=45A and full load then IaFL= 45-1.852
& and the required current at half load will be IaHL = (45-1.852)/2?
Seems too simple!
Joe85 said:
IaHL=21.3635A
Right.
No.
Hint: To maintain half load torque,
the product of field current and armature current after adding field resistance should be equal to the product of field current and armature current before adding field resistance.
Ok so:
21.365 x 2.273 = 48.558A
500/270 = 1.852A.
48.558/1.852A= 26.22A?
Right.
Thank you cnh.
And the speed will just be the same as above: n2 = (n1xe2)/e1 = 606RPM?
Joe85 said:
n2 = (n1xe2)/e1
Only if the flux were constant in both cases..:wink:
Thanks again, So i should begin by trying to work out the flux before the resistance inserted and then after it's inserted to be able to know what the change in speed is?
Yes.
Speed is proportional to back emf/flux.
Right and the only equation that seems of any use to be able to resolve for flux is: E1/E2=Φn1/Φn2. I feel like a complete idiot but I cannot see how to isolate Φ.
Edit: Ok so i believe by using the following equation i can isolate for n2:
n∝V/Φ
and Φ∝If
So n∝E/If and n=(E/If)*K
Which gives:
n2=( n1E2If1) )/( E1If2)
:confused:
Φ is proportional to field current.
Just before you replied i edited this in above, honest :D
n∝V/Φ
and Φ∝If
Which gives:
:confused:
Right.
Thank you. Your assistance and patience is very much appreciated.
  • · Replies 41 ·
  • · Replies 16 ·
9K
