Three Unknown Resistances: Solving for Unknowns in a System of Equations
  • Thread starter Thread starter flash
The discussion focuses on solving for three unknown resistances using a system of equations derived from their relationships. The equations involve reciprocal relationships of the resistances, and the user expresses difficulty in finding a solution. A suggestion is made to take the least common multiple (LCM) of the equations to simplify the problem, leading to a new equation that equates the products of the resistances. This approach is acknowledged as helpful, making the problem easier to tackle. The conversation concludes with appreciation for the guidance provided.
flash
I need to find three unknown resistances given the following three equations:
<br /> \frac{1}{R_2+R_3} + \frac{1}{R_1} = \frac{1}{670}<br />
<br /> \frac{1}{R_1+R_3} + \frac{1}{R_2} = \frac{1}{679}<br />
<br /> \frac{1}{R_1+R_2} + \frac{1}{R_3} = \frac{1}{1349}<br />
I figured since there are three unknowns and three equations it is possible, but I can't see how its done.
Sorry, I'm in a slight hurry, but it may be done in this way,
If you take LCM in all the three equations, you find that the numerator of the LHS becomes equal. If the denominators are take to the RHS, you'll get something like
\displaystyle \frac{R_1(R_2+R_3)}{670}=\frac{R_2(R_1+R_3)}{679}=\frac{R_3(R_1+R_2)}{1349}
The above equation might help as it is much simpler. Maybe you can try solving the above.
Regards,
Sleek
Wow, thanks heaps. Took me a while to figure out how you got that :) It should be a lot easier now.
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 16 ·
  • · Replies 17 ·
