deathcabislov
- 7
- 0
There are two forces. One has a magnitude of 8 N and acts at an angle of 30 degrees on the resultant vector. The resultant vector is 15 N.
equations for components (|a|cosx for horizontal and |a|sinx for vertical)
cos law and sin law
basic trig
First, I drew a diagram. Because the direction of the resultant is not stated, I positioned it going south. I then drew the known vector 30 degrees from the tail of the resultant. So it's tip acted 30 degrees on the tail of the resultant, as stated in the problem. I labelled that as b. Then I drew in the unknown vector, which I labelled as a. It makes an unknown angle with the resultant and has an unknown magnitude.
I tried using the cos law/sin law way of solving this, but all I could figure out is that vector a makes an angle of 60+x degrees with vector b.
I also tried solving with components. I calculated 4N and 7N for the hor. and vert. components of b, respectively and 0N and 15N for the resultant. But after this I am completely lost!
I would really appreciate some feedback just on how I have my diagram set up and maybe some tips on where to go from here, if I have anything correct! Thank you!
