Finding Velocity in Car Collision Impulse Problem
8 replies · 3K views
Bgerst103
A 1343 kg car experiences an impulse of 30,000 N during a collision with a wall. If the collision takes 0.43 s, what was the velocity of the car just before the collision?
A) 22 m/s
B) 9 m/s
C) 51 m/s
D) 18 m/s
F=dp/dt
p=mv
I first tried to work backwards by doing 30,000 x .43 = dp which comes out to be 12900. Since I'm assuming the final momentum is 0, I plugged 12900 into p=mv along with 1343 and got v=9.6. I don't think 9 m/s is the answer, I'm pretty sure it's either A or D but I can't seem to come out with answer close to either. Any help is appreciated.
AlephZero said:
Did you read the question correctly? The units for impulse are not Newtons.
30,000 N/s is what it says.
Are you sure? The units for impulse are as for momentum. Could be kg m/s or, equivalently, Ns (Newton-seconds).
You tried multiplying by the duration, giving you units of kg m (or, Ns2), neither of which relates to any physical quantity I can think of.
Given a time, a momentum and a mass, you want a velocity. What function of the given variables will do that?
rude man said:
Replace 'impulse' with force in the problem statement and you get your answer which I think is correct, the given choices notwithstanding.
On the other hand, leave it as impulse, with units of Newton-seconds, and you do get one of the offered answers.
I ended up getting 22 m/s by just dividing 30,000 N-s by 1343. Not completely sure why that worked but it gave me one of the two answers that I thought it could potentially be.
It worked because the basic equation is impulse = force F times time t = change in momentum Δp = mass m time change in velocity Δv, or
∫Fdt = Δp = mΔv + vΔm but in this case Δm = 0.
The equation follows directly from good old F = ma = m dv/dt so just move the differentials around and integrate both sides of the equation.
