Finding Velocity of a rock thrown into a well
  • Thread starter Thread starter Cheezay
    Rock Velocity
The discussion focuses on calculating the initial speed of a rock thrown into a well 9.17 meters deep, with the splash heard 1.15 seconds later. The correct approach involves separating the time taken for the sound to travel back and the time for the rock to fall. The final calculations yield an initial velocity of approximately -1.91 m/s, accounting for the speed of sound at 343 m/s. Participants emphasize the importance of using consistent time values in the equations to avoid errors.
  • Understanding of kinematic equations, specifically d = Vt + 0.5at²
  • Knowledge of the speed of sound in air (343 m/s)
  • Familiarity with basic physics concepts such as acceleration due to gravity (9.81 m/s²)
  • Ability to manipulate algebraic equations for solving for unknowns
  • Study the derivation and application of kinematic equations in free fall scenarios
  • Learn about the effects of air resistance on falling objects
  • Explore the relationship between sound speed and temperature for more accurate calculations
  • Investigate error analysis techniques in physics experiments to improve accuracy
Students studying physics, particularly those focusing on kinematics and sound propagation, as well as educators looking for practical examples of applying theoretical concepts in real-world scenarios.
Cheezay
A rock is thrown downward into a well that is 9.17 m deep. If the splash is heard 1.15 seconds later, what was the initial speed of the rock? Assume the positive y-axis to point upwards
Time of sound(Ts)= Distance/(343m/s)
Time of stone(Tf)=Total time - Time of sound
Vo=(Height Final - Height Initial)/Tf - 1/2 x g x Tgiven
1.So basically I started off by finding the time it takes for the sound of the stone hitting the water to reach my ears (Ts):
So i took the depth of my well divided by the speed of sound through air:
9.17m/(343m/s)=.026735s
2.Next i subtracted .026735 from the total time to find out how long it takes the rock to hit the water at the bottom of the well (Tf):
1.15s-.026735s = 1.12327s
3. Next using this new time (Tf) i try to figure out velocity, and this is where i think my math is getting screwed up, because i can't get the right answer. Here is my process:
Using the formula Vo=(Height Final - Height Initial)/Tf - 1/2 x g x Tgiven
Vo=(0-9.17m)/1.12327s - (.5)(-9.81m/s^2)(1.15s)
The answer i get is -2.523m/s, which is not right. I am fairly certain the velocity should be negative, since the rock is traveling in the negative direction according to the Y axis parameters given, but other than that i don't know what other mistakes i might be making.
I think my formula for step 3 might be slightly off, but I'm not sure where I'm making my mistake. Big thanks in advance for any help anybody can offer!
In this formula Tgiven should be Tf
Welcome to PF.
Looks OK through 2.
At 3. though you should consider that y = V*t - 1/2g*t2
You know t from 2. and you know y = -9.17 so ...
Thank you both very much for the help, i found the right answer. Problem solved!
Hi, I am also having a problem with this question. It would be helpful if you could actually show the answer that you got (the right answer) and maybe what you were doing wrong intially. It would help me maybe to work through it! I did see that you were missing a 2 on the second t (t2) in your equation 3. Also, instead of using tgiven for equation 3, I am using the tfinal. For your question, I am calculating an intial velocity of -2.66m/s. Was that the answer?
I guess we're using the same TB, but it just has different numbers for this question. My well is 9.0m deep, and the time until you hear the echo is 1.20sec.
My first and second step are identical to yours: I get 0.02624sec for the echo, which leaves 1.2 - 0.02624 = 1.17376sec left for the rock to fall. I know that part is right, but then I suppose the third part is wrong somewhere.
This is how I rearranged my formula for step 3. Is this right?:
d = Vt + 0.5at2
Vt = d - 0.5at2
V = [d - 0.5at2] / t
V = [(-9) - (0.5)(-9.8)(1.173762)] / 1.17376
V = -1.92 m/s
I know that the answer should be negative (it's been thrown downwards), yet that is the wrong answer. I think the math is right and the formula is rearranged just how I have rearranged every other formula, so I'm not sure where I'm going wrong.
Thanks to anyone who can help!
Welcome to PF.
Yes. -2.66 would be the answer for the original problem on my calculator.
And with my rounding I get -1.91 for the math of your problem. One possibility might be that your problem answer doesn't expect you to account for the speed of sound which would certainly affect the answer enough to give an inexact result. (However, if they give you the speed of sound in air as part of the problem then they of course are indicating that you use that.)
The error in the OP was that he was using 2 different time values in the equation - echo corrected and not.
Wow, okay, thank you. Yes -1.91 is the answer and not -1.92 . I can't believe the computer wouldn't accept my first answer! I'll talk to my teacher and maybe he can change my mark. Yeah, the time for the echo is a factor is this question, so maybe that's why this question has a smaller tolerance for rounding errors because even if you didn't use the sound you would get pretty close to the correct answer anyways.
Thanks again.
Thanks again.
Glad it worked out for you. I wasn't being all that careful, as I rounded to 1.734 for the calculation. A .01 difference seems a bit slim for school work.
Yeah, definitely! I've e-mailed my teacher, so I'll see what he says. It is a computer software thing though too, so the computer's answer may have had slightly different numbers too depending on how many decimals they used for their time (ie, using 1.7 instead of 1.7376). We'll see!
