Calculating Velocity for a Soap-Box Car with Rolling Wheels
  • Thread starter Thread starter joemama69
    Velocity
The discussion focuses on calculating the speed of a soap-box car after it travels 100 feet from rest, considering its weight and the properties of its wheels. The car weighs 110 lb, and each of the four wheels weighs 5 lb with a radius of 0.5 ft and a radius of gyration of 0.3 ft. Participants clarify the need to convert weight to mass and apply the appropriate equations for kinetic energy and rotational motion. The calculations lead to a final speed of approximately 56.36 ft/s, confirming the approach and results as correct. The conversation emphasizes the importance of understanding the relationship between linear and rotational dynamics in this context.
joemama69
The soap-box car has a weight of 110 lb, including the passenger but excluding its four wheels. Each wheel has a weight of 5 lb, radius of .5 ft, and a radius of gyration k = .3 ft, computed about an axis passing through the wheels axle. Determine the cars speed after it has traveled 100 ft starting from rest. the wheels roll without slipping. Neglect Air.
T1 = \sumU1-2 = T2
T1 = 0 because it starts from rest
for T2 the mass would be 110lb car pluss the 4 5lb wheels, converted to slugs of course, and the v is what i am looking for
im not sure about the middle term
I = mk3 = .1554*.32 = .013986
What else do i need
What force is acting on the soapbox?
Incline? Angle?
Fy = 130 lb
joemama69 said:
Fy = 130 lb
Isn't that just the weight?
T2 = .5mv2 + .5Iw2
=.5(130/32.2)v2 + .5(130/32.2).32w2
T2 = 325 / 161 v2 + 117 / 644 w2
v = .5w2
T2 = 221/322 w2
\sumU1-2 = V1 - V2, V = Wy
V1 = Wy = W(100sin30)
V2= 0
Therefore
100Wcos30 = 221 / 322 w2
Something aint right
First they have given you the weights. You need the mass.
Second what is sin30? Is that the angle I previously inquired about being given?
oops sorry, i didnt understand when u asked the incline angle
it is 30 degrees
and they hypotenus is 100ft, so 100sin30 = y = 50
I did convert to mass when i divided the weight 130 by 32.2
Also...
When do use the info on the wheels, r = .5, k = .3, w = 5 lb
it is 30 degrees
Also...
Oh, I see. You got it. I see the 32.2 now.
OK the radius of gyration basically gives you the I = m*Rg2
But for your linear translational kinetic energy you have a r = .5 ft
I = mk2 = (5/32.2).32 = 9/644 <-- Should i multiply this my 4 since there are 4 wheels
50W = 1/2(130/32.2)v2 + 1/2 (9/644)w2
w = v/.5
50W = (325/161)v2 + (9/1288)(v/.5)2
50W = 325/161 v2 + 9/322 v2
50w = 659 / 322 v2
v = (16100W) / 659 or v = 24.43095599W
Is this right so far, How do i find W
w = v/.5
50w = 659 / 322 v2
brain fart
W = 130 right
so v = 56.35622 ft/s
anyone agree, disagree
m*g*h = 50*130 = 6500 = 1/2*m*V2 + 1/2*I*ω2
I = 4*5/32.2*(.3)2 = .056
ω = V/.5
6500 = 1/2*(4.037 + .056)*V2
V = 56.36
Looks OK.
  • · Replies 31 ·
