Finding voltage drop across 2k ohm resistor using voltage division
6 replies · 2K views · last reply
pat666
see attached for circuit
from your result from part b, use voltage division to find the voltage drop across the 2k ohm resistor. my result from b was 250V
part b question was voltage drop across 10K resistor
R_T=5k ohms
v=V_2k/V_T = 100v but the answer is 50V?
Thanks
  • Circuit schematic labelled (b) with a 50 mA current source feeding a 10 kΩ resistor and a 5 kΩ resistor, then a 2 kΩ resistor, a 9 kΩ resistor, an 18 kΩ resistor and a 6 kΩ resistor, with a handwritten 15 mA annotation near the 10 kΩ resistor.
What does R_T stand for?
You must have calculated RT wrong.
I get the book answer.
Don't forget the 5kΩ resistor.
The 6kΩ, 18kΩ, and 9kΩ resistors are all in parallel with each other.
That combination is in series with the 5 kΩ and 2 kΩ resistors.
The above is what I would call RT, judging by the way you used RT.
