Finding where electric field is zero with opposite charges
  • Thread starter flyingpig
72 replies · 15K views · last reply
Delphi51 said:
E = kq/(x-1)² works for either charge when to the right of x = 1.
That is, a positive value of q results in a positive E, meaning it points to the right. A negative value of q gives a negative E. But it goes wrong when x < 1.
Can yuo tell me why it cannot be on the right side of q2 of my problem? Because so far the construction is set to find the left, initially we never know.
Diagram of a horizontal line with a blue dot labeled q1 = -2.5 on the left and a red dot labeled +6 on the right. Arrows show E1 near the left and E2 at the right, with text noting E1 is smaller at a distance from q1.
The E1 and E2 due to q1 and q2 cannot be equal to the right of q2 because there we are closer to the larger charge; E2 will always be larger than E1.
Delphi51 said:
Diagram of two point charges on a horizontal line: a blue circle labeled q1 = -2.5 on the left and a red circle labeled +6 on the right. Two small arrow pairs show field vectors, with notes saying E1 can be equal to E2 near the smaller charge and E1 is much smaller than E2 farther from q1.
What happens if the magnitudes are the same? Then how we could decide? Or will the quadratic really work out nicely?
Are there situations when I should use (d + x)?
Also, I noticed in the picture, the way you present the E field vector is almost analogous to the electrostatic force vector.
If the magnitudes are the same and in opposite directions, they cancel out and the total E is zero (as in the left side of my diagram). The quadratic equation finds the exact x value where this occurs.
No, I would never use d + x. The distance from q2 to position x is x-d. Or d-x if you don't care about the sign.
Yes, highly analogous. E is the same as the force vector on a charge of 1C.
No, I mean if q2 = +2.5uC and q1 = -2.5uC, I don't mean q2 = q1 in everyway
Me either. I said E1 and E2 could cancel at a particular spot so E total is zero - the question originally posted here.
[PLAIN]http://img833.imageshack.us/img833/6673/51209057.jpg
Should I use d-x again, but except I will only take positive roots?
[tex]\frac{q_{1}}{(d-x)^2}=\frac{q_{2}}{x^2}[/tex]
Should it be x2 or actually d2?
In view of our experience with the earlier question, better figure out which of the three regions the answer lies in before writing an equation!
Note that this one is more complicated because neither charge is at the origin.
It has to be in between right?
So shouldn't this be correct?[tex]\frac{q_{1}}{(d-x)^2}=\frac{q_{2}}{x^2}[/tex]
That should work if you change the coordinate system so the origin is at Q2 and Q1 is at 10 meters. Then x should work out to some number between 0 and 10.
If you use the given coordinate system, you would use
Q1/(6-y)² = Q2/(y+4)²
and expect an answer for y between -4 and 6.
I know it doesn't matter in this case, but I only need to plug in for the magnitudes of the charges when I get my quadratic right?
Also, even though I know it is in -4 and 6, why cannot it not be outside? I mean as they repel each other, the distance will not be 10 anymore right?
That answer is correct!
It can't be above Q1 because in that region the electric field due to both negative charges is down. Two downs can't add up to zero. Similarly, below Q2, both electric fields are up.
But it can't be 0.1189m
What if I square root both sides? Then I am forced to take the magnitudes only and which I will get 0.85m instead
Oops, terribly sorry! I worked it out using Q1/(6-y)² = Q2/(y+4)² and carefully checked the answer to make sure it was correct. But I never compared your answer with mine. Yours is different. Maybe show your work so we can compare.
Don't leave me! I got an exam in two days and I still got to get my understanding for Gauss's Law
Then square root both sides
√Q1/(6-y) = √Q2/ (y+4)
Cross multiply
√Q1(y+4) = √Q2(6-y)
√Q1y + 4√Q1 = 6√Q2 - y√Q2
y(√Q1 +√Q2) + 4√Q1 - 6√Q2 = 0
y(3 + √8) + 12 - 6√8 = 0
y = (12 - 6√8)/ (3 +√8) = -0.853m
So plug in the numbers and since we got only the square root, we must use the magnitudes and this is what happens even if we end up with the quadratic, we have to use the magnitudes
But if I take the quadratic
y2 +168y - 144 = 0
I get y = 0.853m where I used the magnitudes of the charges
The electric field of a system of point charges is the sum of the contributions of all the individual charges. Let the magnitude of the i-th charge qi and its position vector ri. The electric field at a place with position vector r is
E=sum{kqi(r-ri)/|r-ri|3}.
(http://alumnus.caltech.edu/~muresan/projects/esfields/field.html)
Your need the field along the line connecting two charges, so the y and z coordinates of all position vectors are 0: you get an equation for the x coordinates. Put the origin at the place of q1.
q1 = -2.5 μC, x1=0
q2 = 6 μC, x2= 1 m.
You want to find the x position where the field is zero. Plugging in the given data into the equation above: -2.5 x/|x|^3+6(x-1)/|x-1|^3=0.
Take care of the absolute-value sign ||.
You know that |x|=x if x>0 and |x|=-x if x<0.
In the same way, |x-1|=x-1 if x>1 and |x-1|=-x+1 if x<1.
You have three possibilities: x<0 (on the left of q1), 0<x<1 (between q1 and q2), and x>1 (on the right of q2 ) Try to solve the equation for all cases.
ehild
ehlid, I noticed you used x - d (d = 1.00) instead of d - x...
interesting...
I think this is the third thread I have on this forum that deals with signs...
interesting...
You have tried quite long to get the correct result for this very simple problem. Three peoples have tried to explain the meaning of Coulomb's force. You should remember that the electric field strength is a vector quantity. You can not avoid directions and signs. Try to understand Coulomb's Law and how it has to be applied if there are more than one point charge.
ehild
ehild
I also noticed you did
-2.5 x/|x|^3+6(x-1)/|x-1|^3 = 0
instead of
-2.5 (x-1)/|x-1|^3 +6x/|x|^3 = 0
Why?
Wait, just going back to the new problem, the reason Delph set it up as
For (6-y), this is the units away from the origin and so is y + 4
The way I have been doing is that I am taking the absolute value of the distance doing
Q1/d² = Q2/(d-y)², but this could never work because I have charges below the origin (below the x-axis)
instead of
Why?
Read my post more carefully.
ehild
You've got the answer! Looks like exactly the same work as I had:
-9/(6-y)² = -8/(y+4)²
9(y+4)² = 8(6-y)² after multiplying both sides by common denominator
y² + 168y - 144 = 0
y = 0.8528
I don't think it is a good idea to take the square root of both sides - you would have to be very careful about whether it is 6-y or 6+y if you did that! Nor do you need to take the absolute value of the distance when it is squared.
We used 9 and 8 instead of 9 x 10^-6 in the first step - okay since the 10^-6 on both sides would cancel out.
Ehild has a more sophisticated method that works without knowing in which zone the answer lies, but it is quite a bit more complex mathematically.
y² + 168y - 144 = 0
y = 0.8528
In that link (yahoo) can you tell me what he meant by "Since r₁ is distance from Q1 to null point, then null point is y=0.46"
I know he just subtracted 4, but I don't understand his sentence well.
What happens if both charges are in the negatives??
Ehild has a more sophisticated method that works without knowing in which zone the answer lies, but it is quite a bit more complex mathematically.[/QUOTE]
And it's too much for my brain...
