Finding work done by object along circular helix: Line Integral
4 replies · 5K views · last reply
yolanda
An object weighing 1.2 pounds travels along a helix given by x=cost, y=sint, z=4t, 0<=t<=8pi. Find the work done by the object.
Let's keep this in ft.
g=32.174 ft/s2
f=m*g
f=w*d
r(t)=cos(t)i+sin(t)j+4(t)k
I know I need an F function, but I'm not sure how to find it.
w=[tex]\int[/tex] F(dot)dr
w=[tex]\int[/tex]F(r(t)) (dot) r'(t) dt
Any help would be appreciated, thanks in advance!
You are working against gravity, which is directed downward. So figure out the force f of gravity on your object and use
[tex]\vec F = \langle 0,0,-f\rangle[/tex]
This is the work done by the force, opposite the work done by the object.
Thank you for your response. This may sound a bit stupid, but I want to make sure I'm getting the right force here...
Weight is the mass of an object with a force acting upon it. I'm not sure how much the equations f=ma and weight=m*gravity "overlap", if you will. Can I just say 1.2=mass*gravity? That would mean that the force is 1.2 pounds... do you see what I'm confused about here?
Thanks again for your help!
1.2 pounds is a unit of force in the English system. And work is measured in foot-pounds which gives the right units for w = fd in the English system.
Weight is a force. The formula F = ma gives the force F acting on an object of mass m under an acceleration a.
In the SI system, a mass of 1 kg at the surface of the Earth exerts a force downward of 1kg * 9.8 m/s^2 = 1 Nt. In the English system, a mass of 1 slug at the surface of the Earth exerts a force downward of 1 slug* 32 ft/sec^2 = 32 lb.
They overlap considerably, but the F = ma formula applies more generally for any kind of acceleration, not just that due to gravity.
