Finding Local Extrema and Critical Points for f(x,y)=ysin(x)
  • Thread starter Thread starter oceansoft
The discussion focuses on finding and classifying local extrema for the function f(x,y) = ysin(x). Participants clarify that the goal is to identify critical points by solving the equations ycos(x) = 0 and sin(x) = 0. It is established that the values of x that satisfy sin(x) = 0 are x = nπ, where n is an integer. Substituting these x-values into the equation for y leads to the conclusion that y must be zero, resulting in critical points at (nπ, 0). The conversation emphasizes that there can be infinitely many critical points, confirming the solution is valid.
oceansoft
Find and classify all local minima, local maxima and saddle points for the function
f(x,y)=ysin(x)
i can do this question however i am having problem with finding the x and y intercepts i get
fx= ycos(x) and fy=sin(x)
0=ycos(x) and 0=sin(x)
i start to have problem now after someone can tell me how to find the intercepts i should be fine with the rest of the question thanks.
f(x,y)=ysin(x)
I guess you mean you are having trouble finding the critical points, not the intercepts.
You need to find (x,y) that make both ycos(x) and sin(x) = 0. What x make sin(x) = 0? Do any of them make cos(x) = 0? If you use the x's that make sin(x) = 0 is there any way to make ycos(x) = 0? What (x,y) work in both equations?
So u mean like x= 0, pi, 2pi and so on
and then subing those x's into 0=ycos and then solving for y? but if i do it will go on forever beause it says to find all critical points
Just say that x=\pi n \forall n \epsilon Z
f(x,y)=ysin(x)
Yes, x = n pi make sin(x) = 0. Now answer the next questions I asked:
And, yes, there is nothing wrong with having infinitely many critical points.
Am not too sure what u are asking but if i sub any of the x's i found using sin(x)=0 into cos(x)=0 i will just get 1 or -1 does that mean that y is always equal to zero?
therefore x= n pi and y=0
btw thanks for ur time
Yes, that's exactly it. So your critical points are (n pi, 0).
  • · Replies 27 ·
