Finite differencing on non-uniform grids
  • Level: Graduate
  • Thread starter hunt_mat
    Finite
Homework Helper
Hi,
Recently I had to find a derivative on a uniform grid. Being naive I tried the following scheme:
[tex]f'(x_{n})=Af(x_{n+2})+Bf(x_{n+1})+Cf(x_{n})+Df(x_{n-1})+Ef(x_{n-2})[/tex]
Then write the [itex]f(x_{n\pm i})[/itex] in terms of [itex]f^{(n)}(x_{n})[/itex] by use of Taylor's theorem. This lead to a system of linear equations for the A,B,C,D,E which required inverting a Vandermonde matrix.
I tried it out a couple of times and it worked okay for the first derivative but when I applied it to higher derivatives it became unstable. Does anyone know what is going wrong?
I also tried a seven point stencil in the same way and that bizarrely was even worse.
Mat
It might be helpful to look at the actual matrix you get for a case that causes trouble. It's probably also a good idea to do this for the smallest system possible. If you can see the problem play out on a system you could compute by hand, it might well give you an idea about what's going wrong.
Possibly, but I have tested the 7 point stencil on simple examples and have not got the answers which I should have. The five point stencil however works relative well for first order derivatives but not on higher derivatives (I think)
