Fire & Combustion: Questions Answered
  • Context: Undergrad
  • Thread starter Thread starter Igor_
    Combustion Fire
This discussion focuses on the principles of fire and combustion, specifically addressing ignition temperatures, heat production rates, and heat absorption speeds. It confirms that each material has a unique ignition temperature influenced by its specific heat capacity. The conversation highlights ongoing research into flame propagation speeds and emphasizes the role of thermal conductivity in heat transfer. Key calculations related to these concepts can be explored further through dedicated research.
  • Understanding of ignition temperature and specific heat capacity
  • Familiarity with combustion processes and heat production
  • Knowledge of thermal conductivity and heat transfer principles
  • Basic grasp of flame propagation dynamics
  • Research "ignition temperature calculations for various materials"
  • Explore "flame propagation speed studies and methodologies"
  • Investigate "heat transfer principles and equations"
  • Learn about "thermal conductivity and its impact on heat absorption"
Students, researchers, and professionals in fire science, combustion engineering, and thermal dynamics will benefit from this discussion.
Igor_
I've read a bit about fire on wiki and I have some questions.
1. There is an exact ignition temperature for each material. Temperature reflects the amount of energy, heat. But also specific heat capacity of a each substance is different. So is the amount of heat, which is necessary for of ignition, the same for different substances? If different, why is that so? Can we calculate this amount of heat with formula?
2. If we have a certain amount of fuel we can calculate the amount of heat, which will be produced during combustion. This heat will be produced not immediately, but gradually. So there is a "speed" with which heat is produced. Can we calculate it?
3. If there is the speed of heat production, there might be also the speed of heat absorption. Can we calculate it))?
Thank you very much in advance!
Science news on Phys.org
Hello Igor, :welcome:
1) temperature is the better quantity to consider: heat has a tendency to diffuse away with a rate depending on conductivity (among others).
2) tough one too. but yes, there is a lot of research going on into things like flame propagation speeds. (which google...)
3) again, conductivity (among others) determines how swiftly heat is transported away from wherever it enters. google "heat transfer"
