First Order DE problem (electric circuit)
The discussion focuses on solving a first-order differential equation related to an electric circuit, specifically the charge on a capacitor over time. The integrating factor used is (20+t)5, leading to the solution for charge, q, as q = 4 - (9600000/((20+t)5)). The transient solution is identified as - (9600000/((20+t)5)), while the steady-state solution is 4. The current in the circuit is derived as i = dq/dt = 48000000(20+t)-6, confirming that the maximum current occurs at t = 0, with a value of 0.75.
  • Understanding of first-order differential equations
  • Familiarity with integrating factors in differential equations
  • Knowledge of transient and steady-state analysis in electrical circuits
  • Ability to differentiate functions to find current in circuits
  • Study the application of integrating factors in solving linear differential equations
  • Explore transient and steady-state responses in RLC circuits
  • Learn about the behavior of decreasing functions and their maxima
  • Investigate advanced techniques for solving differential equations in electrical engineering
Electrical engineers, students studying circuit analysis, and anyone interested in solving differential equations related to electric circuits will benefit from this discussion.
forty
(dq/dt) + (5/(20+t))q = 20/(20+t) ... t=0 , q=1
(a) Find the charge on the capacitor at any time.
This is linear so i found the integrating factor which is (20+t)^5
and solved q(20+t)^5 = 20 integral ((20+t)^4) dt
and got q(20+t)^5 = 4((20+t)^5) + C
my C value i got was -9600000
solving for q gave me q = 4 - ((9600000)/((20+t)^5))
(b) Transient and steady state solution
Transient = - ((9600000)/((20+t)^5))
Steady state = 4
(c) Find the current in the circuit at any time, hence the maximum current in the circuit.
current = i = dq/dt
I differentiated and got dq/dt = 48000000((20+t)^-6)
**My problems
Firstly does everything follow, is my logic correct?
Secondly for the maximum current that occurs at t = 0 (presuming my equations are correct) is there anyway of showing working for that, other then stating its at t = 0? (t = 0, i = .75)
Steady state = 4
current = i = dq/dt
**My problems
Yes, everything you've done appears to be correct. As for showing that the maximum current occurs at t= 0, it is sufficient to observe that 48000000(20+t)-6 is a decreasing function. Simply observing that as t increases, the denominator increases, therefore the function decreases is enough- or if you could show that the derivative of i is never 0- therefore has a maximum at an endpoint, t= 0.
OK so just observation is the way to really go, too easy thanks a lot!
