First Order Difference Equations
The problem involves a first-order difference equation representing the amount of water Jill carries out each day, starting with 18 liters on the first day. The equation is given as An+1=0.96*An+2, with the goal of determining the total amount of water recycled over the first week.
  • Exploratory, Mathematical reasoning
  • Participants discuss the method of manually calculating daily amounts and question the efficiency of this approach. There is mention of seeking a formula for the sum of the series. Others suggest exploring the general solution form for difference equations and the possibility of using constants in the solution.
The discussion includes various approaches to solving the difference equation, with some participants suggesting that using the equation for each day is a valid method. There is no explicit consensus on a single approach, but multiple lines of reasoning are being explored.
Participants note the potential complexity of finding a general solution versus calculating daily amounts directly, indicating a preference for practical methods given the short time frame of one week.
diomedes.
Background: Jack's wife Jill, mindful of the water restrictions is determined to carry buckets of bath water out of the house to water bean stalks.
She carries out 18 litres of water on the first day.
The amount of water Jill carries out An, in litres on the nth day is given by the difference equation: An+1=0.96*An+2 , A1=18
Specific: Determine the total amount of water Jill recycles in the first week.
Ok, well I've been working out the answer by finding the total amount recycled each day by manually putting the values into the formula: 1-18 ; 2-19.28 ; 3-20.51 ; 4-21.69 etc and then adding for the total (151.16), but this doesn't seem an efficient way of finding the answer. Is there a formula for the sum (similar to the sums of airthmetic/geometic sequences)?
It is quite possible the answer to this is impossible/obvious, so don't be too harsh :P :)
Have you learned how to solve difference equations? The solution is going to look like A(n)=Crn+D where C and D are constants, so it's the sum of a constant and a geometric progression.
Since [itex]A_{n+1}= 0.96 A_n+ 2[/itex] is a linear equation, we can add solutions to different parts. In particular, we can look for a solution to the equation [itex]A_{n+1}= 0.96 a_n[/itex] first. Since that involves just repeated multiplication, look for a solution of the form [itex]A_n= A_1 r^n[/itex] for some number r. Then [itex]A_{n+1}= A_1r^{n+1}[/itex] and the equation becomes [itex]A_1r^{n+1}= 0.96 A_1r^n[/itex]. Solve that for r.
Now we could probably find a constant that satifies the entire equation, [itex]A_{n+1}= .096 A_n+ 2[/itex] by just substituting the constant, A, for both [itex]A_{n+1}[/itex] and [itex]A_n[/itex]. Then add the two solutions.
But, frankly, since this only involves a week, just using the difference equation for each day is a perfectly valid way of solving this problem. You don't have to use a shotgun to kill flies!
Thanks for the advice chaps! Sounds like I'll just have to suck it up and solve for each day :smile: .
  • · Replies 16 ·
18K
