First order differential equation involving a square root
The discussion centers on a first-order differential equation involving a square root, specifically related to gravitational collapse. Participants express confusion about the solution's components, particularly the function M(R) and its dependency on R. They suggest that M might be a constant, as it relates to the mass of a collapsing star, and clarify that the density ρ is time-dependent. The consensus leans towards a potential typo in the original equation, proposing a corrected solution that aligns with gravitational theory. The conversation highlights the complexities of deriving solutions for such equations in astrophysical contexts.
Lilian Sa
Summary:: solution of first order derivatives
we had in the class a first order derivative equation:
##\frac{dR(t)}{dt}=-\sqrt{\frac{2GM(R)}{R}}##
in which R dependent of time.
and I don't understand why the solution to this equation is:
##R(t)={\frac{3}{2}}^{\frac{3}{2}}{2GM}{\frac{1}{3}}{(t_*-t)}^{\frac{2}{3}}##
thanks
[Moderator's note: moved from a technical forum.]
Are you saying you don't know how to plug that in and check it's a solution, or you don't know how to derive it without already knowing the solution?
Also, why is there an R in the numerator and denominator of the right hand side? Is there a typo?
What is the function ##M(R)##? Note that this differential equation in general is separable.
let me be honest, both.
I just did not understand it.
In the numerator there is M as a function of R, and in the denominator there is the function R.
M is an arbitrary function of R? How does it relate to the M in the solution that you are given? Is that a constant?
I assumed it's supposed to be mass and this has something to do with orbital rotation given the general shape of it, which makes me surprised that M is a function of R to begin with.
Same here. The only thing I can come up with is that the scenario represents a rocket whose mass steadily decreases as the fuel is used up. However, that's just a guess, as there was no additional information provided in the problem statement.
M being an aribtrary function of R is not consistent with the proposed solution.
Rearranging the ODE gives <br /> \frac12 \left(\frac{dR}{dt}\right)^2 = \frac{GM(R)}{R} which is a gravitational potential (assuming that the tangential velocity vanishes and M is constant).
Mentor note: Fixed the LaTeX
It is a collapse of a non relativistic star under its own gravity.
##M(R)=4\pi \int\rho(t)r^2dr##
This doesn't make sense to me. M is a function of R, but R doesn't appear in the integral.
replace r in R.
Lilian Sa said:
replace r in R.
Is this what you mean?
##M(R)=4\pi \int\rho(t)R^2dR##
Ok I am on it now, but why we have in the answer (t_*-t)^(2\3)
Surely it's supposed to be ##M(R)= \int_0^R 4\pi \rho(r) r^2 dr##.
I'm still not sure what M in the proposed solution is supposed to be, since I guess it's not supposed to depend on R.
Edit to add: wait, ##\rho(r)## maybe is supposed to be ##\rho(t)## because as the star collapses its density increases. But if that's the case the mass is probably constant the whole time?
yes rho depends on time
That would seem to require \frac{d}{dt} \left( \frac43 \pi \rho(t) R^3(t) \right) = 0 and hence <br /> \frac 1\rho \frac{d\rho}{dt} = - \frac{3}{R} \frac{dR}{dt} which can be wrangled into the ODE in the OP by taking <br /> \frac{d\rho}{dt} = 3 \rho\sqrt{\frac{GM}{R^3}}<br /> = 3 \rho \sqrt{\frac{4\pi G \rho}{3}}. I've no idea if that is physically justified.
I would expect the equation to be
$$ \bigg(\frac{dR}{dt}\bigg)^2 = \frac{GM}{R} $$
if it where to describe the gravitational collapse of a non-relativistic star, as a fluid parcel located at distance ##R## is gravitational bound (the Viral theorem). But I might be wrong, I haven't really studied these type of systems since I went to gymnasium (college prep school, common in europe).
Nonetheless, I believe that the OP has made a typo and intended to write
$$ R(t) = \Big(\frac{3}{2}\Big)^\frac{2}{3}(2GM)^\frac{1}{3}(t_\ast - t)^\frac{2}{3}$$
as the solution. Which suggest that ## M(R) ## is taken to be constant. If so, the original ODE can be rewritten as
$$ \frac{d}{dt}R^\frac{3}{2} = - \frac{3}{2}\sqrt{2GM} $$
which can be integrated to give
$$ R(t) = \bigg(\frac{3}{2}\sqrt{2GM}(t_0 - t) + R_0^\frac{3}{2}\bigg)^\frac{2}{3} $$
and simplifies to
$$ R(t) = \Big(\frac{3}{2}\Big)^\frac{2}{3}(2GM)^\frac{1}{3}(t_0 - t)^\frac{2}{3},$$
assuming that we are given the "initial" condition ## R(t_0) = R_0 = 0 ##.
  • · Replies 27 ·
  • · Replies 22 ·
