First order linear equation with unsolvable integral and non-linear equation
4 replies · 5K views · last reply
Xyius
Here is an image of the first order linear differential equation and my attempt to solve it. It ends in an integral that can not be solved.
http://img831.imageshack.us/img831/9937/math1.gif
And here is an image of the first order non-linear differential equation and my attempt to solve it. This one leads to a non-separable differential equation after a substitution.
http://img215.imageshack.us/img215/4893/math2.gif
Any advise?
You have:
[tex](1-y)dx+xydy=0[/tex]
You can find the [itex]1/M(M_y-N_x)[/itex] integrating factor for that.
jackmell said:
You have:
The integrating factor isn't working. I was under the impression you can only use the integrating factor only when the two partials differ by a constant only, which they do not. :\
Separable ODE :
  • Handwritten-style derivation of a separable ODE: xy dy/dx = y - 1 leads to (1/x) dx = y/(y-1) dy, then ln(x) = y + ln(y-1) + constant, then x(y) = x0(1-y)exp(y), and boxed solution y(x) = 1 + W(X) with X = -x/(e x0), where W(X) is the Lambert W function.
y(x) cannot be expressed in terms of a finite number of elementary functions. The closed form requires a special function :
  • Handwritten-style derivation: x^2 dy/dx + y = x^2; solution y(x) = exp(1/(2x^2)) times the integral of (1/x) exp(-1/(2x^2)) dx; then y(x) = (-1/2 Ei(X) + C) exp(1/(2x^2)) where X = -1/(2x^2) and Ei(X) is the exponential integral function.
