First order Partial differential equation
The discussion revolves around solving a first-order partial differential equation (PDE) of the form $$\frac{1}{x^2}\frac{\partial u(x,y)}{\partial x}+\frac{1}{y^3}\frac{\partial u(x,y)}{\partial y}=0$$ with a specific boundary condition related to the derivative of the solution at a boundary defined by $$\frac{\partial u(x,y)}{\partial x}\big |_{y=0}=x^3$$ for all values of $$x$$.
  • Participants discuss the general solution form $$u(x,y)=f(\frac{x^3}{3}-\frac{y^4}{4})$$ and explore how to apply the boundary condition effectively. There is a focus on the relationship between the derivatives and the boundary condition, with attempts to express $$f$$ in terms of $$z$$ and $$x$$. Some participants question the notation used for derivatives and suggest alternatives for clarity.
Participants are actively engaging with the problem, providing insights into the notation and the implications of the boundary condition. There is recognition of potential confusion arising from the notation, and suggestions are made to clarify the approach to finding the function $$f$$. No consensus has been reached on a definitive solution yet, but the discussion is progressing with constructive feedback.
There is an acknowledgment of the challenges posed by the boundary condition and the notation used in the derivations. Participants are considering how to properly integrate and express the relationships involved without leading to confusion.
pondzo
Find a solution of $$\frac{1}{x^2}\frac{\partial u(x,y)}{\partial x}+\frac{1}{y^3}\frac{\partial u(x,y)}{\partial y}=0$$
Which satisfies the condition ##\frac{\partial u(x,y)}{\partial x}\big |_{y=0}=x^3## for all ##x##.
I get the following general solution for the PDE:
$$u(x,y)=f(\frac{x^3}{3}-\frac{y^4}{4}):=f(z)$$
For some function f which satisfies the BC. I'm not too sure how to deal with this type of boundary condition. But here is an attempt:
##\partial_x u=\frac{\text{d}f}{\text{d}z}\frac{\partial z}{\partial x}=\frac{\text{d}f}{\text{d}z} x^2##. Thus ##\frac{\text{d}f}{\text{d}z} x^2=x^3\implies \frac{\text{d}f}{\text{d}z} =x\implies f(z)=zx##
At ##y=0,~ z=\frac{x^3}{3}\implies x=(3z)^{\frac{1}{3}}##. So ##f(z)=(3z)^{\frac{1}{3}}z##, and changing variables back gives
##u(x,y)=(3(\frac{x^3}{3}-\frac{y^4}{4}))^{\frac{1}{3}}(\frac{x^3}{3}-\frac{y^4}{4})=3^{\frac{1}{3}}(\frac{x^3}{3}-\frac{y^4}{4})^{\frac{4}{3}}##
This is a solution to the PDE but doesn't satisfy the given boundary condition, it is out by a factor 3/4 and I'm not sure why.
You got to the point:
[itex]\frac{df}{dz} = x[/itex]
But to integrate that, you have to have the right side as a function of [itex]z[/itex]. On the border [itex]y=0[/itex], you have:
[itex]z = \frac{x^3}{3}[/itex], which means [itex]x = (3z)^\frac{1}{3}[/itex]
So your equation becomes:
[itex]\frac{df}{dz} = (3)^{\frac{1}{3}} z^{\frac{1}{3}} \Rightarrow f(z) = 3^{\frac{1}{3}} \frac{z^\frac{4}{3}}{\frac{4}{3}}[/itex]
You are being led astray by poor notation! It is better in problems such as this to avoid the ##df/dx## notation for derivatives, and use ##f'## instead. The point is that ##f'(u) = df(u)/du## is just a function of ##u##---never mind for the moment that it is a derivative. Your equation ##x^2 f'(x^3/3) = x^3## becomes ##f'(x^3/3) = x ##, or ##f'(u) = (3u)^{1/3}##. Now do ##\int f'(u) \, du## to find ##f(u)##. Then, and only then, put back ##u## in terms of ##x## and ##y##.
Thank you guys, I knew it must have been something silly like that.
Hi Ray, I really don't like the notation I use to solve these types of questions because as you say it can become confusing at times. What would your solution to a question like this look like? with particular emphasis on the notation used.
Sometimes it helps to define another function temporarily, so you could say something like "let ##g(u) = df(u)/du##... ". Then your boundary equation would be
[tex]x^2 g\left( \frac{x^3}{3} \right) = x^3[/tex]
Of course, using a new notation ##g( \cdot) ## is not really necessary, since using ##f'## instead works perfectly well, if you realize that ##f'## is a whole new function on its own. The fact that it happens also to be a derivative if ##f## is not important in some parts of the working.
