Fixing LaTeX Not Working on Firefox 99
  • Context: LaTeX
  • Thread starter Thread starter carpinus
    Latex Work
13 replies · 3K views
carpinus
hello,
I am trying to use latex in a thread, but for some reason it does not work, eg. v^a is displayed as v^a
I am using firefox browser version 99.
many thanks for your help
Let me try ##v^a##
works for me
I used #.#.v^a.#.# without the dots. The double number signs cues Mathjax that there’s an expression in Latex to be rendered.
there's a link to a latex tutorial below in my signature area.
carpinus said:
hello,
Reply to this post to see what I posted.
For an inline equation ##ax^2 + bx + c = 0## and for a separate line $$ax^2 + bx + c = 0$$
sorry, I was unclear
I tried using the dollar or the hash sign from the beginning and they don't work
I remember fixing a post in a thread that used single $ around a theta that was also missing a backslash.
$.theta.$ vs $.$.\theta.$.$
( remove the dots from the expressions to make them render correctly. )
There's also a link in the input pane every time you start a thread or write a response to one.
now it seems to work.
at the beginning some strange things happened.
e.g. it was as though I had to log out and log in again to get the code rendered.
at some point I used 'save draft' and 'delete draft'.
thank you very much for your advice
If you are the first writing LaTeX in a thread it will not render immediately. Try to reload the page in those cases.
When trying to demonstrate ##\LaTeX## in a thread, one can prevent the ## and $$ from rendering by using the little palette icon to select a color for one of the # signs or one of the $ signs.
So one can write that ##\sqrt{2}## is written as ##\sqrt{2}##
Edit: The pallete icon gives you a friendly way to insert things like into your text. Those BB code tags get in the way of the MathJax tags and prevent them from rendering.
Edit 2: If you reply to this and use the [ ] icon to turn off BB code rendering, you can see what I did here.
That's exactly how I do it.
