Flatlander analogy of spherical surface as observable universe
  • Context: High School
  • Thread starter Thread starter Catastrophe
The discussion revolves around the analogy of a flatlander living on the surface of a sphere as a means to understand concepts related to the observable universe and its expansion. Participants explore the implications of this analogy in the context of modern cosmology, particularly regarding dimensions and the nature of space-time.
  • Some participants propose that the flatlander analogy can represent the observable universe, suggesting that the surface of the sphere encapsulates the dimensions of the universe, including time.
  • Others argue that the analogy may not effectively visualize modern cosmological concepts, noting that the geometric properties of a flatlander's universe do not align well with the actual structure of the universe as measured.
  • A participant suggests that the analogy implies the need for an additional dimension to understand the concept of "expansion into what," although this claim is contested.
  • Another viewpoint asserts that the mathematical framework of expansion does not necessitate an additional dimension and that the issue of "into what" is a non-problem in the context of cosmic expansion.
  • Some participants emphasize that while curved spacetime can be visualized in higher dimensions, the mathematics does not require them, and any proposed additional dimensions must have measurable consequences to be considered valid.
  • There is a contention regarding whether the flatlander analogy is meant to explore properties of a surface without invoking extra dimensions, with some arguing that it is misleading to assume additional dimensions are necessary.
Participants express differing views on the utility and implications of the flatlander analogy, with no consensus reached on its effectiveness in representing cosmological concepts or the necessity of additional dimensions.
Some claims made in the discussion depend on specific interpretations of the analogy and the mathematical framework of cosmology, which may not be universally accepted or understood among all participants.
Catastrophe
TL;DR
Analogy of 'flatlander' inhabiting spherical surface suggests that 'universe' implies 'observable universe' and that an observer must be considered. Thus observable universe is a relative term.
I have addressed the analogy of a flatlander inhabiting the curved surface of a sphere. At first, I considered the 'radius' as representing time, but, latterly, I prefer the surface representing the entire (2 dimensions + time, i.e., flatlander observable universe).
Space news on Phys.org
Catastrophe said:
TL;DR Summary: Analogy of 'flatlander' inhabiting spherical surface suggests that 'universe' implies 'observable universe' and that an observer must be considered. Thus observable universe is a relative term.
You are basically right about what is meant by "observable universe", and also that the word "observable" is often left out.
But I am not seeing how the analogy with a flatlander on the surface of a two-sphere is helping us visualize anything in modern cosmology. You might want to take a moment to consider how a flatlander could conclude that their two-dimensional universe is the surface of a sphere:
- Locally, if measured with sufficient accuracy the interior angles of a triangle will not add up to quite exactly 180 degrees; initially parallel straight lines will eventually intersect; the pythagorean theorem won't work; and the like.
- Globally, if the flatlander stays in the same place long enough they will see the back of their head somewhere out in the far distance.
None of this behavior corresponds well with the actual structure of the universe (as best we have been able to measure) so I would be very cautious about any intuition suggested by your analogy. To be useful, I think you would have to be more clear about the ways in which the analogy does match the real thing and which conclusions drawn from it can be trusted.
  • Agree
QUOTE
QUOTE
To me, the analogy suggests that an additional dimension, beyond that perceivable by the (ND) is required. That is (ND+1). That suggests that we may require an additional dimension (which we cannot access) to understand "expansion into what?".
I never suggested that a flatlander could conclude any such thing. In fact, such a conclusion would be impossible (on my definition).
  • Skeptical
But we already understand the "expansion into what?" issue, i.e. there is no issue. Expansion by the very definition means that distance between two bodies that are not gravitationally bounded (e.g. two galaxy clusters) grows with (cosmic) time. There is no space (hehe) for "into what?" issues in the math. It's a non-existing problem.
I do understand that laypeople have issues, because they do not study the math of expansion, but some pop-sci sources that try to explain it by other means.
It isn't. Curved spacetime is often visualised using a 2d sheet embedded in a 3d space, true, but the higher dimensional embedding space is entirely for the purposes of illustration. There's no need in the maths for the it (everything is defined with respect to measurements made in 4d spacetime) and no observational or experimental evidence for one.
In short, you can propose additional dimensions if you like, but unless you can find a measurable consequence of them it's just proposing undetectable unicorns.
To me, this means you totally missed the point of the analogy. The analogy is all about investigating the properties of a surface without using any additional dimensions. In the case of something like the surface of the Earth, it's easy to be misled about this because we know there is an extra dimension present. But in the case of the universe, we have no reason to believe that's the case, and the Flatlander analogy lets us analyze the properties of the universe anyway.
Not to worry. I am happy with my position on this. Thanks for your comments.
Cat :) :) :)
  • Skeptical
  • · Replies 42 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 25 ·
