Fluid Dynamics Problem: Effects of a Full Reservoir
The discussion focuses on the fluid dynamics of a reservoir system fed by a mountain spring, specifically addressing the behavior of water flow when the reservoir is full. The system consists of a two-inch pipe from the spring to a 40-gallon drum, which has three outlets: a two-inch cleanout channel, a 3/4-inch pipe leading to the reservoir, and a 3/4-inch upper overflow pipe. The main inquiry is whether a vacuum forms in the drum when the upper overflow fills, potentially affecting the flow rate through the lower overflow pipe. The consensus indicates that a vacuum can indeed form, impacting the flow dynamics.
  • Understanding of fluid dynamics principles
  • Knowledge of pipe flow and pressure concepts
  • Familiarity with vacuum formation in closed systems
  • Basic skills in sketching fluid systems for visualization
  • Research "Bernoulli's Principle" and its application in fluid systems
  • Study "Hydraulic calculations for pipe systems" to understand flow rates
  • Explore "Vacuum formation in fluid dynamics" and its implications
  • Learn about "Overflow systems in reservoir management" for practical applications
Engineers, hydrologists, and anyone involved in designing or analyzing fluid systems, particularly those dealing with reservoirs and overflow management.
jmrathbun
If this isn't the right forum, please move me to a better one.
Assume that the output of a mountain spring is diverted to a reservoir about 200 feet below the spring through the following airtight system:
A two inch pipe leads from the spring to a 40-gallon drum that lies on its side a few feet below the spring; this pipe enters the drum near the top of one end. The drum has three outlets on its other end:
  • At the bottom, a two inch cleanout channel has a short run and is normally closed with a valve
  • In the middle, a 3/4 inch pipe goes down to the top of the reservoir, where there is a short overflow channel of 3/4 inch pipe
  • At the top, a 3/4 inch overflow pipe terminates a few feet below the barrel
The output of the spring is variable. I'm interested in the situation where the reservoir is full and there is more water coming into the barrel than the lower overflow pipe can accommodate. Once the upper overflow pipe fills, does a vacuum form in the barrel that prevents free flow to the reservoir so that the lower overflow pipe would run less full than the upper one?
Can you provide a sketch?
CS
Sorry I don't have much in the way of drawing skills but here's my attempt :blushing:
  • · Replies 45 ·
  • · Replies 31 ·
  • · Replies 51 ·
10K
