Fluid Dynamics: Waterflow out of a Tank
  • Thread starter Thread starter Noorac
    Tank
The discussion revolves around fluid dynamics, specifically focusing on the flow of water from a cylindrical tank through a hole at its base. The problem involves understanding the relationships between various speeds and heights, as well as the time it takes for water to fall to the ground from a certain height.
  • Participants explore the relationship between the speed of water flowing out of the hole and the speed at which the water level drops. They question how these speeds relate to the height of the water in the tank.
  • Some participants suggest using derivatives to express the relationship between the height of the water and the speed at which it drops.
  • There is discussion about modeling the water's trajectory as a projectile and how to calculate the distance it travels horizontally before hitting the ground.
  • Questions arise regarding the application of Bernoulli's equation and the conservation of mass in the context of the problem.
The discussion is active, with participants providing insights and suggestions for approaching the questions. Some guidance has been offered regarding the use of derivatives and the separation of horizontal and vertical motion in projectile problems. Multiple interpretations of the relationships between variables are being explored.
Participants note the importance of conservation of mass and the assumption of constant air pressure and gravity in their discussions. There is an acknowledgment of the complexity of the relationships involved and the need for careful consideration of the variables at play.
Noorac
Hi, this is some questions about fluid dynamics(mostly). There are three somewhat connected questions here, I will try to organize it as best as I can.
A sylindrical tank filled with water is standing on a table, the tank has a small hole at the side of the tank at the very bottom(not underneath). The tank is placed on the table so that the water coming out of the hole will drop directly to the floor(it won't touch the table).
Variables:
height of table(height from the hole in the tank to the ground) = H
height of waterlevel inside the tank = h
(inside)Radius of hole at the bottom of the tank = r
(inside)Radius of the tank = R
Speed at which the waterlevel inside the tank drops = V
Speed of the water flowing out of the hole = v
Distance on the floor, from the floor directly beneath the hole to where the water hits the floor = L.
I've added a sketch of the variables.
The airpressure is constant everywhere, g is gravity and works in the negative y direction, and the density of the water is constant.
Q1: What is the relation between the speed v and the speed V?
Q2: The speed V is related to the timedependancy of height h by some differentiate. What is the relation?
Q3: What is the length L as a function of height h?
- Bernoullis equation for incompressible liquid(see attempt at solution).
A1: The relation can be given by [itex]\rho t v \pi r^2 = \rho t V \pi R^2 = constant[/itex]
Wich means [itex]vr^2 = VR^2 = constant[/itex]. I don't know what more i need to do in order to show the relation, is this enough?
A2: I don't know how to solve this.
A3: I used Bernoullis equation to get a model for v: [itex]v = \sqrt{2gh}[/itex]. So now I have the speed v out of the hole(i think), but don't know how to get from there. It is supposed to be a function of height h, so I think I'm not supposed to mix time into it, in which case it would be easier.
I'm mostly interested in a small push in the right direction, and any help would be much appreciated=)
Edit: I forgot to say the mass is conserved!
V is the speed the water level drops. Look at its units. What derivative in variable h has the same units and, of course, defines the same thing.
This is a typical projectile being shot off a cliff problem.
Hmm, okey, so given that my A1 is correct, I would think I could solve Q2 like this:
Velocity is the derivative of position with respect to time, so if h is the displacement:
[itex]\frac{dh}{dt} = V(t)[/itex]
If I am correct in A1, then [itex]vr^2 = VR^2[/itex] which means [itex]\frac{vr^2}{R^2} = V(t)[/itex] which again means; [itex]\frac{dh}{dt} = \frac{vr^2}{R^2}[/itex]. Is this correct?
And for Q2: I haven't really been doing any cannonball off cliffs problems, but I would solve it as:
[itex]v(t) = \sqrt{2gh} \Rightarrow position = t\sqrt{2gh}[/itex] which represents the position of the water in x-direction as a function of time. And:
[itex]acc = -g \Rightarrow Velocity = -gt \Rightarrow position = -\frac{1}{2}gt^2[/itex] which represents the position of the water in y-direction, giving me:
[itex]position = x(t) = \sqrt{2gh} \boldsymbol{i} - \frac{1}{2}gt^2 \boldsymbol{j}[/itex] Wich I guess would be nice for a graph. But how do I go from there? Would it be possible to solve it as a quadratic equation (?) :
[itex]x(t) = -gt^2 + \sqrt{2gh}t + H[/itex], and pick the positive root?
Unless I am misunderstanding the question, I would simply answer by saying V = dh/dt.
For the water passing through the air part, first determine how long it takes the water to reach the ground. The basic assumption is that the horizontal velocity is constant. The portions of these problems are solved separately. You already have written the correct formula to determine the time for it to reach the ground - y-direction computation for t. Solve for t and use it to determine range L.
I'm going to work a bit more on it tomorrow=) Thanks for all the help!
  • · Replies 17 ·
