Fluid Manometer Question: Determining Height and Pressure
  • Thread starter Thread starter LauraMorrison
    Fluid Manometer
4 replies · 7K views
LauraMorrison
The manometer illustrated in Fig. Q2 contains water and kerosene (specific
gravity of 0.82) as indicated. With both ends of the U-tube open the height
H0 =20 mm.
(i) Determine the height, h , when both ends of the tube are open. [4]
(ii) Determine the new value of H0 when a gauge pressure of 98 Pa is
applied to the right end of the U-tube. [6]
2. The attempt at a solution
I can do part (a), getting an answer of 91.1mm.
However, I am stuck on part (b).. I assume I cannot keep h constant and see the variation in Ho with the added pressure?
I am unsure how to work out the two unknowns h and Ho with only the one equation.
Are you sure h doesn't change? In my lecturers solutions it does change.. I don't really understand his solutions but maybe you can explain?
I have attached his solution.
Oh I see, sorry I didn't read that carefully enough. Thank you I get it now! :)
