Fluid Mechanics problem - cylinder over a orifice
20 replies · 4K views · last reply
Saitama
The horizontal bottom of a wide vessel with an ideal fluid has a round orifice of radius ##R_1## over which a round closed cylinder is mounted, whose radius ##R_2>R_1##. The clearance between the cylinder and the bottom of vessel is very small, the fluid density is ##\rho##. Find the static pressure of fluid in the clearance as a function of the distance r from the axis of the orifice (and the cylinder), if the height of the fluid is equal to ##h##.
I think I have to apply the Bernoulli's equation but I need two points to apply the Bernoulli equation. How do I find those points? :confused:
I understand I should show some more attempt but I really can't get the intuition behind these fluid mechanics problem so I am unable to make any attempt.
Any help is appreciated. Thanks!
You might start with two points where you know some information. For example, what can you learn by picking points 1 and 2 as shown?
Hi Pranav-Arora! :smile:
No, you need a streamline …
Bernoulli's equation is always and only valid along a streamline.​
Once you've drawn a streamline, it should be obvious what to do next. :wink:
Hi TSny and tiny-tim! :smile:
I use the streamline shown by TSny and the reference line is a line passing through 2.
From Bernoulli's equation,
$$P_1+\rho gh+\frac{1}{2}\rho v_1^2=P_2+\frac{1}{2}\rho v_2^2$$
I am not sure but is ##P_1=P_2## as both points are open to atmosphere or medium outside? Also, how do I relate ##v_1## and ##v_2##? :confused:
Pranav-Arora said:
… how do I relate ##v_1## and ##v_2##? :confused:
Draw circles round the hole …
since the density is constant, isn't it obvious from the geometry how the speed must increase as the circles get smaller? :wink:
Yes, I do understand that speed increases as the hole size decreases. Okay, so let the area of hole in clearance be s and that of wide vessel be S. From equation of continuity, ##Sv_1=sv_2## but what now? Do I approximate ##v_1## equal to zero? :confused:
the pressure (under the cylinder) is a function of r
the pressure in the outlet should be the same as if the cylinder wasn't there :wink:
I don't think I get this, can you please elaborate a bit more? :redface:
the gauge pressure for an outlet (to the atmosphere) is zero, so that gives you v in the outlet :wink:
tiny-tim said:
the static pressure for an outlet (to the atmosphere) is zero, so that gives you v in the outlet :wink:
So that means ##v_2=\sqrt{2gh}##? But the question asks something else...
yes, it asks for P as a function of r, as r moves away from the rim of the hole
Hehe tiny-tim. :P
But I don't get why you asked me to find the speed, I am honestly not sure what to do with it. How do I find the pressure as a function of r? :confused:
Bernoulli's equation gives you the pressure if you know the speed. :wink:
The fluid is going to be entering the hole horizontally (i.e., radially), so the volumetric throughput rate entering the hole is going to be [itex]2\pi R_1t\sqrt{2gh}[/itex], where t is the clearance. Once you know the volumetric throughput rate, you can get the fluid velocity at any radial location r.
Hi Chestermiller!
Okay, I see that you find the rate of flow of liquid but I still don't get how to find the pressure as a function of r.
Do I have to apply Bernoulli at 2 and at some distance r from the axis?
Pranav-Arora said:
Hi Chestermiller!
Yes. You have the pressure and velocity at r = R1, and you have the velocity at arbitrary r, so you use the Bernoulli equation between these two locations to get the pressure at r.
Thanks Chestermiller and tiny-tim! :smile:
Applying Bernoulli at 2 and at a distance r,
$$P_o+\frac{1}{2}\rho(\sqrt{2gh})^2=P(r)+\frac{1}{2}\rho v^2$$
From equation of continuity, I have
$$A(r)v=2\pi R_1t\sqrt{2gh} \Rightarrow 2\pi rtv=2\pi R_1t\sqrt{2gh} \Rightarrow v=\frac{R_1\sqrt{2gh}}{r}$$
Substituting in Bernoulli and solving for P(r),
$$\boxed{P(r)=P_o+\rho gh\left(1-\frac{R_1^2}{r^2}\right)}$$
(##P_o## is the atmospheric pressure)
tiny-tim said:
yes, that looks right :smile:
Thanks tiny-tim! :)
I compared my answer with the answer given in book. The book shows the condition that ##R_1<r<R_2##. I don't get this. Why not ##R_1 \leq r \leq R_2##? The P(r) I have found is valid for ##R_1##, I am not sure about ##R_2## though.
i agree with you …
it seems obviously valid for R1, but "at" (or even near) R2 there's likely to be some "edge effect" (related to the movement not being entirely horizontal)
all this is academic … for an "ideal" fluid and "ideal" cylinder, your limits are just as good as the book's! :smile:​
tiny-tim said:
i agree with you …
Thank you once again tiny-tim! :smile:
