Solve Fluid Mechanics Homework: Q, m, t, P
The discussion focuses on solving a fluid mechanics homework problem involving the flow of hot oil through a pipe. Key calculations include the volumetric flow rate (Q) of 2.514 x 10^-4 m³/s, the mass flow rate (m) of 0.18 kg/s, and the inlet pressure (P) calculated to be 16 kPa. The time required to fill a 3 m³ tank is derived from the volumetric flow rate, emphasizing a straightforward relationship between flow rate and tank volume.
  • Understanding of fluid mechanics principles
  • Familiarity with volumetric flow rate calculations
  • Knowledge of mass flow rate and specific gravity concepts
  • Ability to apply pressure calculations using force and area
  • Learn about fluid dynamics and Bernoulli's equation
  • Study the concept of flow rate in different pipe diameters
  • Explore the relationship between pressure, force, and area in fluid systems
  • Investigate real-world applications of mass flow rate in engineering
Students studying fluid mechanics, engineers working with fluid systems, and anyone involved in solving practical problems related to fluid flow and pressure calculations.
smosikas
A hot oil(specific gravity = 0.7) flows through a pipe of 4 cm internal diameter, at a velocity of 0.2 m/s. Determine:i) The volumetric flow rate of the oil discharged from the pipe.
ii) The mass flow rate of the oil discharged from the pipe.
iii) If the pipe discharges the oil to a tank of 3 m^3 volume, how long does it take to fill the tank?
iv) If the force applied to the pipe inlet due to the oil flow is 20N, find the inlet pressure.
The attempt at a solution:
i) Volumetric flow rate: Q=vA
A= πr^2 --> A= π*0.02^2 = 1.257*10^-3 m^2
Q= 0.2*1.257*10^-3= 2.514*10^-4 m^3/s
ii) Mass flow rate: m=ρQ
Specific Gravity : SG=ρ(oil)/ρ(water) -> ρ(oil)=SG*ρ(water) -> ρ(oil)= 0.7*1000= 700 kg/m^3
m= 700*2.514*10^-4 = 0.18 kg/s
iii) ?
iv)Pressure= force/area -> P=20/1.257*10^-3 = 15910.89Pa = 16kPA
Hi, I am having tough times trying to solve this question. If You find it easy please teach me! Any help will be greatly appreciated! Because i can't seem to wrap my head around this question :(
You have gotten the same answers I got. I think you may have it!
Thank you! But what about the time it takes to fill the tank?
That should be the easiest one of all to figure.
Look, if you put X cubic meters per second into a tank which has a total capacity of Y cubic meters, what amount of time does this take?
After 1 second, there is X cubic meters in the tank; after 2 seconds, there is 2X; etc., etc. Rinse and repeat until you have accumulated Y cubic meters.
You should be able to solve this using the dimensions of the quantities alone.
Thank you! i thought there was more to it than that
11K
